What are the real and complex roots of z = exp(-z)?
  • Thread starter Thread starter gmans
    Complex Roots
The equation z = exp(-z) can be rewritten as z = e^(-z), which is a complex problem involving both real and imaginary components. To solve it, define z as a + ib, where a and b are real numbers, and consider the polar form z = |z|exp(iΦ). The equality of two complex numbers requires their moduli and polar angles to match, leading to the need to equate |z| and the angles appropriately. This approach provides a structured method to explore the roots of the equation. Understanding these concepts is essential for tackling this mathematical challenge.
gmans
of the equation
z= exp(-z)
could someone possibly point me in the right direction to start this problem?
this area of math is still new to me so please go easy
thanks
I moved this thread to the homework section. gmans, what do you mean by the equation that you have written? What is "exp" representing?
Probably, he means:
z=e^{-z}
That's a fun problem. I say start by defining z=a+ib where a and b are real numbers and also note z=|z|exp(i\Phi) the polar form of z, so that you're looking for the solutions to
|z|e^{i\Phi}=e^{-a-ib}
And use the fact that two complex numbers are equal iff their modulus are the same and their polar angle are the same up to a difference of 2n\pi, n\in\mathbb{Z}.
