Challenging Integrals in Calculus 1-2: Expand Your Problem-Solving Skills!
  • Context: Undergrad
  • Thread starter Thread starter pakmingki
    Hard Integrals
This discussion focuses on challenging integrals suitable for Calculus 1 and 2, with participants sharing various complex integrals such as \(\int \frac{(1+x^{2})dx}{(1-x^{2})\sqrt{1+x^{4}}}\), \(\int e^{-x^2} dx\), and \(\int_{0}^{\infty} \sin(x^2)dx\). The integrals discussed range from those that can be solved using standard techniques to those that require advanced methods, such as Gaussian integrals and polar coordinates. Participants express both excitement and frustration regarding the difficulty of these integrals, highlighting the beauty and complexity of calculus.
  • Understanding of basic integral calculus concepts
  • Familiarity with techniques such as u-substitution and integration by parts
  • Knowledge of improper integrals and limits
  • Basic understanding of polar coordinates and multivariable calculus
  • Study Gaussian integrals and their applications in calculus
  • Learn advanced integration techniques, including contour integration
  • Explore the properties of special functions like the Error function
  • Investigate the convergence of improper integrals and oscillatory integrals
Students and educators in calculus, mathematicians interested in advanced integration techniques, and anyone looking to enhance their problem-solving skills in integral calculus.
  • #91
Pranav-Arora said:
This one is fairly straightforward, use the substitution ##x=\tan\theta##.
For this one, define:
$$I(a)=\int_0^1 \frac{x^a-1}{\ln(x)}dx$$
Differentiate both the side with respect to a to get:
$$\frac{dI}{da}=\int_0^1 x^a\,dx=\frac{1}{a+1}$$
$$\Rightarrow I(a)=\ln|a+1|+C$$
It can be easily seen that C=0. We need the value of I(a) when a=1, hence,
$$I(1)=\ln(2)$$
We use the series expansion of ##\ln(1-x)## i.e
$$\ln(1-x)=-\sum_{k=1}^{\infty} \frac{x^k}{k}$$
Hence, our integral is:
$$-\int_0^1 \frac{1}{x}\sum_{k=1}^{\infty} \frac{x^k}{k}\,dx$$
$$=-\sum_{k=1}^{\infty} \int_0^1 \frac{x^{k-1}}{k}\,dx$$
$$=-\sum_{k=1}^{\infty} \frac{1}{k^2}=-\zeta(2)$$
Are you sure about the tan substitution? I couldn't solve it that way, but I'm not very good
  • #92
Hi dumbperson! :)
Yes, I am sure about it. After the substitution, you should get:
$$I=\int_0^{\pi/4} \ln(1+\tan\theta)\,d\theta$$
Also,
$$I=\int_0^{\pi/4} \ln\left(1+\tan\left(\frac{\pi}{4}-\theta\right)\right)\,d\theta=\int_0^{\pi/4} \ln\left(1+\frac{1-\tan\theta}{1+\tan\theta}\right)\,d\theta=\int_0^{\pi/4} \ln(2)-\ln(1+\tan\theta) \,d\theta$$
$$\Rightarrow I=\frac{\pi \ln2}{4}-I \Rightarrow \boxed{I=\frac{\pi \ln2}{8}}$$
I hope that helps.
  • #93
Pranav-Arora said:
Hi dumbperson! :)
Also,
I hope that helps.
Ah cool, thanks!
  • #94
Not really a hard one but try this: \displaystyle\int 1-\sin x\cos x\tan x\,dx
  • #95
Some of my most memorable ones from calc I, should take a few coffees to solve:
$$\int_{0}^{∞} \frac{1}{x^2 + \sqrt{x}} dx$$
$$\int_{0}^{\frac{\pi}{4}} \frac{1}{1 + sin^2(x)} dx$$
  • #96
if we divide both the numerator and the denominator by \frac{1}{cos^{2}x} the integral becomes
\displaystyle\int_{0}^{\frac{\pi}{4}} \frac{sec^{2}x}{1+2tan^{2}x} dx
We can make the substitution t = tan(x)
I guess you can solve the first one by making the sub u = \sqrt{x} and then using partial fractions decomposition
  • #97
This one was a 1968 Putnam competition problem, I believe:
{\int_{0}^{1}{\frac{x^4 (1-x)^4}{1+x^2} dx}}
The answer is really interesting...
If you're really up for a challenge, try this continuation:
{\int_{0}^{1}{\frac{x^8 (1-x)^8 (25+816x^2)}{3164(1+x^2)} dx}}
These are just tedious and definitely easier than many of the problems here.
-- Joseph
  • #98
The 1st one is not tedious:
- \int_{0}^{1} \frac{(1-x^4 -1)(1-x)^4}{1+x^2} dx = - \int_{0}^{1} (1-x)^5 (1+x) dx + \int_{0}^{1} \frac{(1-x)^4}{1+x^2} dx
For the 1st integral, just sub 1-x = p and it will be trivial.
For the 2nd integral, write the integrand as
\frac{(1-x)^2 (1-x)^2}{(1-x)^2 + 2x} = (1-x)^2 - \frac{2x(1-x)^2}{(1-x)^2+2x} = (1-x)^2 - 2x\frac{1-x^2}{1+x^2} + \frac{4(1+x^2)-4}{1+x^2}
The integration of the 4 terms is elementary.
  • #99
Can you explain in more detail exactly what you did there please? I see that ##x^4 = -(-x^4 +1 - 1)## and then I don't see how you got to the next step.
I had a good time with this one:
\int_{\to 0}^{\to 1}\ln x \ln (1-x) \, \mathrm dx
(+7 points if you prove that it exists before evaluating it)
  • #100
$$\int_0^1 \ln x\ln(1-x)\,dx=-\sum_{k=1}^{\infty} \frac{1}{k}\int_0^1 x^k\ln x\,dx=\sum_{k=1}^{\infty} \frac{1}{k(k+1)^2}$$
$$=\sum_{k=1}^{\infty} \frac{1+k-k}{k(k+1)^2}=\sum_{k=1}^{\infty} \frac{1}{k(k+1)}-\sum_{k=1}^{\infty} \frac{1}{(k+1)^2}$$
Both the sums are easy to evaluate, the first one evaluates to 1 by telescoping series and the second one is simply ##\zeta(2)-1##, hence, the final answer is ##2-\zeta(2)##.
-- Joseph
http://en.wikipedia.org/wiki/Proof_that_22/7_exceeds_π
  • #101
Ha, nice trick to find an article on wikipedia about those 2 integrals. :)
  • #102
Not terribly hard but something I've found interesting
\int_{0}^{1}\sin (\ln(x)) dx
  • #103
This one is really easy. Sub x=e^y. The rest is either that trick with the repeated integration by parts or transforming \sin y to a complex exponential form.
  • #104
$$\int^1_0 \log^2(x)\log^2(1-x)\,dx$$
  • #105
\int^2_0 \sin{x^2}\,dx
  • #107
Compute:
$$\int_{0}^{1}\int_{0}^{1} \frac{y^2 -x^2}{(x^2 +y^2)^2} dx{}~{}dy $$
  • #108
  • #109
I'm curious to see what technique you guys would use to solve ## \int_{-1}^{1} \frac{\cos(x)}{\exp(1/x) + 1}dx ##
  • #110
ObsessiveMathsFreak said:
\int e^{-x^2} dx
prasannapakkiam said:
how can this even be integrated?:rolleyes:
You don't. You use a power series for that one. Hahaha.
  • #111
itsjustme said:
sin(2x)cos(2x)dx
\int{\sin{2x}\cos{2x}dx} = \frac{1}{2} \int{\sin{4x}} = -\frac{1}{8} \cos{4x}
  • #112
DyslexicHobo said:
I'm just out of Calc 1, so I'm not sure if I even have the knowledge to solve this... but here's where I am now. I can't tell if I complicated it even more, or if I'm closer to getting the solution.
\int (r-1)^{1/5}ln(r) - r^{-1} (r-1)^{1/5} dr
I used u-substitution (well, r-substitution), where r = x^5 + 1. After the substitution I used integration by parts, and now I'm unsure if that was even the right path. Please let me know!
And please tell us how to do \int_{0}^{\infty}sin(x^2)dx
To integrate \int_{0}^{\infty}sin(x^2)dx we use \int_{0}^{\infty}sin(x^n)dx =\Gamma{(1 + \frac{1}{n})}\sin{\frac{\pi}{2n}} = \frac{\sqrt{\pi}}{2\sqrt{2}}
  • #113
Give this one a chug:
$$\int x \sqrt{ax^2 + bx + c}$$
  • #114
I would rewrite it as ##\displaystyle \frac{1}{2a}[\int(2ax + b)\sqrt{ax^2 + bx + c}dx - b\int\sqrt{ax^2 + bx + c}dx]##
The first integral is of the form ##\displaystyle \int f'(x)g(f(x))dx## and can be solved easily by either inspection or applying the sub##\displaystyle ax^2 + bx + c = u##.
The second integral is evaluated by completing the square and applying a hyperbolic sine sub.
  • #115
Disclaimer: A friend told me about this and I do not know the answer yet.
Disclaimer 2: This is not really an integration problem but very close. (If you think it should not be here, please tell me, I will remove it)
Try this one,
(dy/dx) + 3 = (dy/dx) + 2
Apparently, it does have a solution (or so I am told and yes, I am still working on the problem)
  • #116
Try this one,
Any vertical line (x=a) satisfies.
"∞ = ∞" :biggrin:
  • #117
\displaystyle\int_0^\infty e^{-\sqrt[2015] x} dx = 2015!
True or false? Prove your answer. Came up with this one myself :D
  • #118
That's true, I think. I'm lazy to do the maths, but you can make an obvious substitution, then use the definition of the Euler Gamma function.
  • #119
This one isn't too hard, but it is really cool:
\int^{\infty}_{-\infty} \frac{1}{x^2 + 1} \, \mathrm{d}x
  • #120
Wouldn't it just be zero?
-You substitute x = tan u
-You get [arctan x] from (-inf) to (+inf) which is 0
