Really ugly graph-volume problem
  • Thread starter Thread starter Nikitin
Nikitin
Find the volume of the solid generated by revolving the region about the x-axis.
Region = the area separated by given function and lines:
x = sqrt(2y)/(y^2 +1)
y=0.
i just need to solve the integral of ∫x dy... How? Is there any simple way to solve it?
y=0.
Don't you want ##\pi\int x^2\, dy##? Write out your integral, complete with limits so we know exactly what your problem is.
that would be the case if I wanted to revolve it around the Y-axis.
Here's a graph showing the problem:http://desmond.imageshack.us/Himg14/scaled.php?server=14&filename=63679970.jpg&res=landing
i need to find the area between the y=1 and the graph (which I require the integral of x to find). that way I can find the average radii of the solid, remake it into a cylinder with the same area and revolve it to find a volume identical to the 1 I'm supposed to find.
Duno if this will work, tho.
Yes, I was thinking you were revolving about the Y axis. I see you have added the line y=1 to the problem. To revolve about the x-axis given you have x in terms of y, you want to use a dy integral and the shell method with an integral of this form:$$
V =2\pi\int_a^b yf(y)dy= 2\pi\int_0^1\frac{\sqrt 2 y^\frac 3 2}{1+y^2}\, dy$$which isn't quite the form in your original post. Whether that is an easy integral to work isn't obvious to me at the moment.
Yes, your method sounds much better than mine. I just learned the shell method yesterday so I don't have any problems with that.
But the integral of x needs to be solved anyway (and it's without thinking about 2*pi outside, imo).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
