Rearranging equation into another form.
  • Thread starter Thread starter Sherry Darlin
    Form
Sherry Darlin
I have a transfer function as part of a circuit analysis question which I obtained as:
-{\frac {{\it R2}}{ \left( {\it sC1}\,{\it R1}+1 \right) \left( {\it <br /> R2}\,{\it sC2}+1 \right) }}
Which needs to be turned into:
I have attempted by multiplying the top and bottom of the fraction by R1, s, C1, etc, trying to manipulate to get into the required form, but no luck yet.
Are C's and R's related in any way?
Suppose you set C1 = 0. Then the first expression is finite whereas the second one is zero.
C stands for the capacitance, and R is the resistance.
I guess I should have said C and R are non-zero. I would put the circuit diagram, but it wouldn't make sense unless you can understand it, although it's pretty easy.
I'm not sure what you mean by are they related. It's like having an equation in x and y.
Thanks for your response.
If s, R and C are independent, then there is a typo somewhere, as the two equations are not always equal.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
