I Reason for Gram's Law about Zeta Zeros
  • I
  • Thread starter Thread starter Swamp Thing
    Law Reason
Gram's Law describes the tendency of the Zeta function, particularly on the critical line, where the real part of the Zeta function tends to be positive, indicating a correlation with the cosine function. The distinction between "good" and "bad" Gram points relates to the behavior of the Zeta function at these points, affecting the positivity of the integral involving Z(t). While Gram's Law primarily applies when the Zeta function is real, it appears to hold more broadly along the critical line. The discussion includes a formula for the sum of products of Z values at Gram points, suggesting a deeper relationship in their distribution. The Lambert W function is referenced as part of the formula used to approximate the behavior of theta for large t.
Mathematics news on Phys.org
I suppose you could phrase Gram's law as the statement that ##\Re(\zeta(\frac{1}{2}+it))## tends to be positive, or that ##Z(t)## is somehow positively correlated with ##\cos\theta(t)##. Although Gram's law only applies when ##\zeta(\frac{1}{2}+it)## is real, it seems to hold elsewhere on the critical line as well. The plot of ##\Re(\zeta(\frac{1}{2}+it))## is mostly positive, whereas the imaginary part appears to fluctuate rapidly:
WolframAlpha--__0_70_cos_RiemannSiegelTheta_x___RiemannSiegelZ_x__dx______2021_01_04_15_23.gif
WolframAlpha--__0_70_cos_RiemannSiegelTheta_x__pi_0_5__RiemannSiegelZ_x__dx______2021_01_04_15...gif
In particular, ##\int_0^T\cos\theta(t)\cdot Z(t)\,dt## is positive and large, while ##\int_0^T\sin\theta(t)\cdot Z(t)\,dt## is relatively small and might be positive or negative.
Actually, apparently there is a formula ##\sum_{n\leq N} Z(g_{n-1})Z(g_n) \sim -2(\gamma + 1)N##, which I found a few pages into this paper. I plotted the autocorrelation function of ##Z(g_n)## (integrating from 0 to 100,000) using the approximate formula ##g_n=2\pi e^{1+W(\frac{8n+1}{8e})}##:
Normalized plot of ##f(\tau)=\int_0^{10^5} Z(g(t))Z(g(t+\tau))\,dt##:
I don't really have a full understanding of what I'm doing, but this is all very intriguing to me.
Likes Swamp Thing
Thank you.. I'm reading now on a mobile device but I'll probably get back later with a question or two.
What is the "W" in this formula?
That's the Lambert W function. Nothing special, it's just there since ##\theta(t)\sim \frac{t}{2}\log\frac{t}{2\pi}## for ##t## large, and so its inverse function can be approximated using W.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
