Recent Noteworthy Physics Papers
  • Thread starter Thread starter ZapperZ
    Papers Physics
the thread highlights recent noteworthy physics papers published in respected peer-reviewed journals, emphasizing the importance of providing full references and abstracts. Key papers discussed include a new determination of the fine structure constant through precise measurements and QED calculations, a detailed model of pebble erosion, and experimental investigations into entangled measurements that challenge local realism. Other significant contributions involve studies on the behavior of mesoscopic circuits and the interplay between electron-lattice interactions and superconductivity in high-Tc materials. The thread serves as a resource for sharing and recognizing impactful research in the field of physics.
  • #251
L. Prochaska et al., "Singular charge fluctuations at a magnetic quantum critical point." Science v.367, p.285 (2020).
Abstract: Strange metal behavior is ubiquitous to correlated materials ranging from cuprate superconductors to bilayer graphene. There is increasing recognition that it arises from physics beyond the quantum fluctuations of a Landau order parameter which, in quantum critical heavy fermion antiferromagnets, may be realized as critical Kondo entanglement of spin and charge. The dynamics of the associated electronic delocalization transition could be ideally probed by optical conductivity, but experiments in the corresponding frequency and temperature ranges have remained elusive. We present terahertz time-domain transmission spectroscopy on molecular beam epitaxy-grown thin films of YbRh2Si2, a model strange metal compound. We observe frequency over temperature scaling of the optical conductivity as a hallmark of beyond-Landau quantum criticality. Our discovery implicates critical charge fluctuations as playing a central role in the strange metal behavior, thereby elucidating one of the longstanding mysteries of correlated quantum matter.
ArXiv version of this paper may be found here.
This is a very tedious and difficult experiment, especially in the growth of a pristine sample to actually be able to detect this effect. This is another example where the principle of quantum criticality is often most apparent in a condensed matter system.
And oh, note that this material is antiferromagnetic, which is similar to the "parent" or undoped state of the cuprate high-Tc superconductors, that are also believed to have quantum criticality underlying the various properties.
Zz.
  • #252
Testing the Seesaw Mechanism and Leptogenesis with Gravitational Waves
Jeff A. Dror et al.
Phys. Rev. Lett. 124, 041804 – Published 28 January 2020
DOI: 10.1103/PhysRevLett.124.041804
Abstract said:
We present the possibility that the seesaw mechanism with thermal leptogenesis can be tested using the stochastic gravitational background. Achieving neutrino masses consistent with atmospheric and solar neutrino data, while avoiding nonperturbative couplings, requires right handed neutrinos lighter than the typical scale of grand unification. This scale separation suggests a symmetry protecting the right-handed neutrinos from getting a mass. Thermal leptogenesis would then require that such a symmetry be broken below the reheating temperature. We enumerate all such possible symmetries consistent with these minimal assumptions and their corresponding defects, finding that in many cases, gravitational waves from the network of cosmic strings should be detectable. Estimating the predicted gravitational wave background, we find that future space-borne missions could probe the entire range relevant for thermal leptogenesis.
  • #253
Transition from Static to Dynamic Friction in an Array of Frictional Disks
Harish Charan, Joyjit Chattoraj, Massimo Pica Ciamarra, and Itamar Procaccia
Phys. Rev. Lett. 124, 030602 – Published 24 January 2020
https://journals.aps.org/prl/abstract/10.1103/PhysRevLett.124.030602
The nature of an instability that controls the transition from static to dynamical friction is studied in the context of an array of frictional disks that are pressed from above on a substrate. In this case the forces are all explicit and Newtonian dynamics can be employed without any phenomenological assumptions. We show that an oscillatory instability that had been discovered recently is responsible for the transition, allowing individual disks to spontaneously reach the Coulomb limit and slide with dynamic friction. The transparency of the model allows a full understanding of the phenomenon, including the speeds of the waves that travel from the trailing to the leading edge and vice versa.
Popular report here
https://arstechnica.com/science/2020/02/flat-surfaces-surf-past-each-other-on-the-peak-of-a-wave/
I find it interesting that
  1. friction can be studied by statistical mechanics,
  2. that dynamic friction could be an emergent property
  3. that a simulation based on a hypothetical array of disks could relate to real physics.
  • #254
Direct Measurements of Collisional Dynamics in Cold Atom Triads
L. A. Reynolds, E. Schwartz, U. Ebling, M. Weyland, J. Brand, and M. F. Andersen
Phys. Rev. Lett. 124, 073401 – Published 18 February 2020
https://doi.org/10.1103/PhysRevLett.124.073401
Abstract said:
The introduction of optical tweezers for trapping atoms has opened remarkable opportunities for manipulating few-body systems. Here, we present the first bottom-up assembly of atom triads. We directly observe atom loss through inelastic collisions at the single event level, overcoming the substantial challenge in many-atom experiments of distinguishing one-, two-, and three-particle processes. We measure a strong suppression of three-body loss, which is not fully explained by the presently availably theory for three-body processes. The suppression of losses could indicate the presence of local anticorrelations due to the interplay of attractive short range interactions and low dimensional confinement. Our methodology opens a promising pathway in experimental few-body dynamics.
An article on this paper at phys.org:
https://phys.org/news/2020-02-physicists-individual-atoms-groundbreaking.html
  • #255
Mesoscale All-Atom Influenza Virus Simulations Suggest New Substrate Binding Mechanism
Jacob D. Durrant, Sarah E. Kochanek, Lorenzo Casalino, Pek U Ieong, Abigail C. Dommer, Rommie E. Amaro
ACS Cent. Sci. 2020, 6, 2, 189-196
https://doi.org/10.1021/acscentsci.9b01071
Influenza virus circulates in human, avian, and swine hosts, causing seasonal epidemic and occasional pandemic outbreaks. Influenza neuraminidase, a viral surface glycoprotein, has two sialic acid binding sites. The catalytic (primary) site, which also binds inhibitors such as oseltamivir carboxylate, is responsible for cleaving the sialic acid linkages that bind viral progeny to the host cell. In contrast, the functional annotation of the secondary site remains unclear. Here, we better characterize these two sites through the development of an all-atom, explicitly solvated, and experimentally based integrative model of the pandemic influenza A H1N1 2009 viral envelope, containing ∼160 million atoms and spanning ∼115 nm in diameter. Molecular dynamics simulations of this crowded subcellular environment, coupled with Markov state model theory, provide a novel framework for studying realistic molecular systems at the mesoscale and allow us to quantify the kinetics of the neuraminidase 150-loop transition between the open and closed states. An analysis of chloride ion occupancy along the neuraminidase surface implies a potential new role for the neuraminidase secondary site, wherein the terminal sialic acid residues of the linkages may bind before transfer to the primary site where enzymatic cleavage occurs. Altogether, our work breaks new ground for molecular simulation in terms of size, complexity, and methodological analyses of the components. It also provides fundamental insights into the understanding of substrate recognition processes for this vital influenza drug target, suggesting a new strategy for the development of anti-influenza therapeutics.
I know it's on the biochem side, but the size of this MD simulation blew my mind: all-atom (160 million atoms) totally solvated 121-ns simulation of an influenza virus in 1-fs timesteps. I remember how big a deal it was about a decade ago when Klaus Schulten's group did the first 1-million atom simulation (of satellite tobacco mosaic virus), but this makes that work look like small potatoes.
  • #256
Constraint on the matter–antimatter symmetry-violating phase in neutrino oscillations
Nature volume 580, pages339–344(2020)
https://www.nature.com/articles/s41586-020-2177-0
The charge-conjugation and parity-reversal (CP) symmetry of fundamental particles is a symmetry between matter and antimatter. Violation of this CP symmetry was first observed in 19641, and CP violation in the weak interactions of quarks was soon established2. Sakharov proposed3 that CP violation is necessary to explain the observed imbalance of matter and antimatter abundance in the Universe. However, CP violation in quarks is too small to support this explanation. So far, CP violation has not been observed in non-quark elementary particle systems. It has been shown that CP violation in leptons could generate the matter–antimatter disparity through a process called leptogenesis4. Leptonic mixing, which appears in the standard model’s charged current interactions5,6, provides a potential source of CP violation through a complex phase δCP, which is required by some theoretical models of leptogenesis7,8,9. This CP violation can be measured in muon neutrino to electron neutrino oscillations and the corresponding antineutrino oscillations, which are experimentally accessible using accelerator-produced beams as established by the Tokai-to-Kamioka (T2K) and NOvA experiments10,11. Until now, the value of δCP has not been substantially constrained by neutrino oscillation experiments. Here we report a measurement using long-baseline neutrino and antineutrino oscillations observed by the T2K experiment that shows a large increase in the neutrino oscillation probability, excluding values of δCP that result in a large increase in the observed antineutrino oscillation probability at three standard deviations (3σ). The 3σ confidence interval for δCP, which is cyclic and repeats every 2π, is [−3.41, −0.03] for the so-called normal mass ordering and [−2.54, −0.32] for the inverted mass ordering. Our results indicate CP violation in leptons and our method enables sensitive searches for matter–antimatter asymmetry in neutrino oscillations using accelerator-produced neutrino beams. Future measurements with larger datasets will test whether leptonic CP violation is larger than the CP violation in quarks.
Evidence of CP violation in leptons. Seems pretty important.
  • #258
GW190521: A Binary Black Hole Merger with a Total Mass of ##150\ M_\odot##
R. Abbott et al. (LIGO Scientific Collaboration and Virgo Collaboration)
Phys. Rev. Lett. 125, 101102 – Published 2 September 2020
https://doi.org/10.1103/PhysRevLett.125.101102
Abstract said:
On May 21, 2019 at 03:02:29 UTC Advanced LIGO and Advanced Virgo observed a short duration gravitational-wave signal, GW190521, with a three-detector network signal-to-noise ratio of 14.7, and an estimated false-alarm rate of 1 in 4900 yr using a search sensitive to generic transients. If GW190521 is from a quasicircular binary inspiral, then the detected signal is consistent with the merger of two black holes with masses of ##85^{+21}_{−14}  M_\odot## and ##66^{+17}_{−18} \ M_\odot## (90% credible intervals). We infer that the primary black hole mass lies within the gap produced by (pulsational) pair-instability supernova processes, with only a 0.32% probability of being below ##65 M_\odot##. We calculate the mass of the remnant to be ##142^{+28}_{−16}  M_\odot##, which can be considered an intermediate mass black hole (IMBH). The luminosity distance of the source is ##5.3^{+2.4}_{−2.6} \ \text{Gpc}##, corresponding to a redshift of ##0.82^{+0.28}_{−0.34}##. The inferred rate of mergers similar to GW190521 is ##0.13^{+0.30}_{−0.11} \ \text{Gpc}^{−3} \ \text{yr}^{−1}##.
Likes mfb
18K
