Hunter's Recoil Speed from Rifle Shot
  • Thread starter Thread starter henry3369
    Speed
The discussion revolves around calculating the recoil speed of a hunter firing a rifle on a frictionless surface. The hunter's mass is 72.5 kg, and the rifle shoots 4.20 g bullets at 950 m/s at an angle of 52 degrees. Using conservation of momentum, the recoil speed was initially calculated in both the x and y directions, leading to a combined speed of 0.055 m/s. However, it was clarified that the hunter does not move in the y-direction due to the ice surface, which affects the calculations. The correct recoil speed is ultimately determined to be 0.0339 m/s, emphasizing the importance of considering the constraints of the environment.
henry3369
A hunter on a frozen, essentially frictionless pond uses a rifle that shoots 4.20g bullets at 950m/s . The mass of the hunter (including his gun) is 72.5kg , and the hunter holds tight to the gun after firing it.
Find the recoil speed of the hunter if he fires the rifle at 52.0∘ above the horizontal.
Vx = 950cos(52)
Vy = 950sin(52)
Conservation of Momentum in the x-Direction:
m1v1' = -m2v2'
(72.5)v1' = (-0.0042)(950cos(52))
v1' = -0.033882611 m/s
Conservation of Momentum in the y-Direction:
m1v1' = -m2v2'
(72.5)(v1') = (-0.0042)(950sin(52))
v1' = -0.043367764 m/s
vf = sqrt(0.0338826112+0.0433677642) = 0.055 m/s
The correct answer is 0.0339 m/s
What am I doing incorrectly?
Is the hunter free to recoil in the Y-direction?
I know that the hunter wouldn't move in the y-direction, but wouldn't there still be an initial velocity in the y-direction? Similar to how if an object is dropped, it has a y-component of velocity right as it hits the ground.
The hunter is already on the ice surface. Any velocity in the downward direction would have to include the ice and the rest of the planet.
