Recoil velocity after collision
  • Thread starter Thread starter diffusion
    Collision Velocity
In a collision involving a particle of mass 1.00u and a stationary Cu nucleus of mass 62.93u, the particle rebounds in the opposite direction with a speed of 0.9687v. To find the recoil velocity of the Cu atom, conservation of momentum must be applied, considering the initial momentum equals the final momentum. The momentum equation yields that the Cu atom's recoil velocity is approximately 0.0005v. Participants in the discussion emphasize the importance of accounting for direction when calculating momentum. The final consensus is to express the Cu atom's recoil velocity correctly in terms of v.
diffusion
A particle of mass 1.00u traveling at speed v, collides with a stationary Cu nucleus of mass 62.93u, and rebounds in the exact opposite direction with a speed of .9687v. What is the recoil velocity of the Cu atom, in terms of v?
F=ma
P=mv
If the recoil of the proton is .9687v and the initial velocity was v, then in order to satisfy conservation of momentum, .0313u/v must be transferred to the Cu atom. To solve for velocity of the Cu atom, use p=mv; 0.0313 = 62.93 x v. Therefore v = 0.0005v.
Am I correct or just going in the completely wrong direction here?
Use conservation of linear momentum, you find that the total linear momentum before collision = v
Total linear momentum after collision remains the same and the sum equals v.
Hint : Account for the direction of the particle after collision
I'm getting the same answer, but still feel like I'm on the wrong track.
Total linear momentum = v = 1.0(.9687) + 62.93(0.00050v).
:cool: What would be the direction of velocity of the particle after the collision?
Wouldn't it be 1.0(.9687 v)? Velocity is a vector, so we have to take into account the direction the body is moving in..
Negative along x-axis for the proton. Positive for the Cu atom.
Yes.Correct.
So wouldn't one take the velocity of the proton to be negative?
Now, you can write the momentum conservation equation.
sArGe99 said:
Yes.Correct.
So if the velocity and therefore momentum of the proton is -.9687, the momentum of the Cu particle would have to be... .9687 + .9687 + 0.0313 = 2.2504. Divide by 62.93 = velocity of 0.0357v.
I'm so far off.
The momentum conservation equation would be
v = -0.9687v + 62.93 u
Express u, the recoil velocity of Cu atom in terms of v. That is the way its found out, I believe.
