Recovering lagrangian from equations of motion
tulip
Hi guys, I have a question about finding a lagrangian formulation of a theory.
If I have a system for which I know the equations of motion but not the form of the lagrangian, is it possible to find the lagrangian that will give me those equations of motion? Is there a systematic way of doing this?
Thanks to anyone who can help!
I don't think there is. Basically you have to guess your Lagrangian and check that it gives you the correct equations of motion.
It may (some times) be impossible to find a Lagrangian that identically reproduces a given set of equations as its Euler-Lagrange equations. Indeed, action principle is not very useful for describing systems in which viscosity or heat transfer is important. In most such cases no Lagrangian / action is known. However, if an action /Lagrangian does exist, we can indeed reconstructed. Let me show you how;
We know that if an action S[\phi] is given, then the equations of motion are
E(\phi) = \frac{\delta S[\phi]}{\delta \phi(x)}= 0 \ \ \ (1)
where \delta S / \delta \phi is the variation derivative of the action with respect to the dynamical variables \phi(x);
\delta S[\phi] = \int d^{n}x \frac{\delta S}{\delta \phi(x)} \delta \ \phi(x) \ \ \ (2)
Suppose now that eq(1) is given and we want to reconstruct S[\phi]. In order to do this, we introduce a (homotopy) parameter \lambda \in [0,1], and let
\phi(x) \rightarrow \lambda \phi(x)
in eq(1);
E(\lambda \phi) = \frac{\delta S}{\delta \phi}|_{\phi = \lambda \phi}
Next, we use eq(2) to write the derivative of S[\lambda \phi] with respect to \lambda;
<br /> \frac{d}{d\lambda}S[\lambda \phi] = \int d^{n}x \frac{\delta S}{\delta \phi}|_{\phi = \lambda \phi}\ \frac{d}{d\lambda}(\lambda \phi ) = \int d^{n}x \ E(\lambda \phi ) \ \phi (x)<br />
Integrating this equation from \lambda = 0 to \lambda = 1 gives (up to an arbitrary additive constant);
<br /> S[\phi] = \int d^{n}x \int_{0}^{1} d \lambda \ E(\lambda \phi )\ \phi (x) \ \ \ (3)<br />
Finally, we may need to integrate by parts and throw away all surface terms before reading off the Lagrangian from eq(3).
For example let us reconstruct the Lagrangian which leads to the following equation of motion;
\partial_{a}\partial^{a}\phi + \cos (\phi^{2}) = 0
From eq(3) we get , after integrating the 1st term by part,
<br /> S[\phi] = \int d^{n}x \int_{0}^{1} d\lambda \{ - \lambda \partial_{a}\phi \partial^{a}\phi + \phi \cos (\lambda^{2}\phi^{2}) \}<br />
From this we find our Lagrangian;
<br /> \mathcal{L} = - \frac{1}{2}\partial_{a}\phi \partial^{a}\phi + \int_{0}^{1}d\lambda\ \phi \ \cos (\lambda^{2}\phi^{2})<br />
Ok, I leave you to reconstruct an action/ Lagrangian which has
\partial_{a}\partial^{a}\phi - \sin (\phi) = 0
as its Euler-Lagrange equation.
Regards
sam
Likes Arantxa
Let me ask a related question: how can one proof/see if there is or there is NOT an action for a given set of equations of motion? :) Are there references for this?
samalkhaiat -> Have been looking for something like this in the past but all I could find was clever guessing work... thanks for posting!
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
