How Does Current Direction Affect Force in a Rectangular Loop?
The discussion focuses on calculating the magnetic forces acting on a rectangular loop of wire carrying a current in a magnetic field. The loop has dimensions of 4 cm by 5 cm and carries a current of 2.8 A in a uniform magnetic field of 3.8 × 10^-4 T. The user has successfully calculated the torque for the x-axis and y-axis but is struggling to determine the forces Fa and Fb for the z-axis. The formula F=I*L*B sin(theta) is provided to find these forces, but the user is encountering difficulties with the calculations. Assistance is sought to verify the values being used in the formula to resolve the issue.
ahazen
A rectanglular loop consists of 5 turns of wire carrying a current of 2.8 A. The loop is in the x-y plane, and the direction of flow of the current is shown in the figure. The loop has dimensions a = 4 cm and b = 5 cm. Consider a uniform magnetic field of strength 3.8 × 10-4 T in x, y, or z directions.
I need to find the:
-Fa on x-axis
-Fb on y-axis
-Fa on z-axis
-Fb on z-axis
For the X-axis, I found that torque is 1.064e-5 and Fb=0
For the y-axis, I found the torque is 1.064e-5 and Fa=0
I also found that the torque for z-axis is 0.
But, how do I find the other Fa and Fb?
I am given: F=I*L*B sin(theta)
Hi ahazen,
I need to find the:
-Fa on x-axis
-Fb on y-axis
-Fa on z-axis
-Fb on z-axis
By Fa, I assume you mean the magnitude of the magnetic force on side a due to the magnetic field, right? If so, then you have the formula; if you plug in your values (all you have to determine here is what theta is) what do you get?
yes, that's correct:) I'm still trying to work on the problem. Something is not working right when I plug the values in.
You seem to have the right formula; if you post the values you are plugging in and the result you get, I or someone else can try to verify it.
