Redox Reactions: Ionic vs Covalent Compounds
Not all ionic reactions qualify as redox reactions. For instance, the reaction between NaNO3 and HCl does not involve a change in oxidation numbers, indicating it is not a redox process. While many ionic reactions, particularly those with transition metals, are redox, this is not a universal rule. Additionally, elements in covalent compounds do not always have oxidation states of zero. Oxidation states vary based on established rules for different elements, as illustrated by the example of H2S, where hydrogen has an oxidation state of +1 and sulfur has -2. Understanding these oxidation states is essential for grasping the nuances of chemical reactions.
gsingh2011
Hi, I just learned about oxidation and reduction reactions and I have some questions.
Are all ionic reactions redox reactions?
Do elements that make up covalent compounds always have an oxidation number of zero because they only share electrons, not give or take? That is what I was thinking, but according to my book, in the molecule H2S, H has an oxidation of +1 and S has one of -2, which doesn't make sense if its a covalent compound...
Thanks.
Chemistry news on Phys.org
No, not all ionic reactions are redox. Let's say you react NaNO3 and HCl. There is no change in oxidation numbers for the reactants, so it isn't redox. A lot of reactions involving ionic compounds are redox, especially ones involving transition metals, but not all of them are.
And no, elements in covalent compounds do not always have oxidation states of zero. There are certain rules regarding oxidation states for each common element, which should be in your book. Read a little more about oxidation states and this will make more sense.
Hope this helps, feel free to ask more questions if you have them
Perhaps a better example would be
Ag+ + Cl- -> AgCl
It is obvious that reaction takes place, it takes place between ions, and it is not a redox reaction.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
