Why Must Sodium Borohydride Be Added Slowly in Benzophenone Reduction?
  • Thread starter Thread starter ephemeral1
    Reduction
Adding sodium borohydride slowly to benzophenone during reduction to benzhydrol is crucial for controlling the heat released in the reaction, preventing potential hazards such as explosions. The reaction is conducted in iced water to further manage temperature and ensure safety. After the reaction, the solid product is dissolved in hot methanol, and water is added to reach a cloudy point, which indicates the formation of diphenylmethanol. The addition of water is necessary to facilitate the reaction and protonate the diphenylmethoxide ion. Given the low solubility of diphenylmethanol at room temperature, the resulting cloudiness suggests the presence of this compound in the solution.
ephemeral1
Why do you have to add sodium borohydride slowly to reduce benzophenone to benzhydrol? And why do we have to place the reaction in iced water?
Chemistry news on Phys.org
Because you need to control the amount of heat released in the reaction. You don't want the whole thing to explode... or maybe you do. That might be a fun thing to try.
After we got the solid from the reaction of benzophenone with sodium borohydride, then we dissolved the solid in a minimum amount of hot methanol. Why do we add the same amount of water to get the resulting solution to a cloudy point?
The methanol, I assume, would isolate the (former) benzophenone, and water is needed to complete the reaction. (any acidic substance with a pKa than can protonate a diphenylmethoxide ion, really) Since diphenylmethanol has a solubility of just 0.5 g/L at room temperature, the cloudy stuff is probably that.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
