Kinetic Energy | Earth Satellite vs. Truck: Same Ref Frame?
The comparison of kinetic energy between a satellite in geostationary orbit and a truck traveling at 60 mph is not realistic due to differing reference frames. Both the satellite and truck are in accelerating reference frames, complicating direct comparisons. When viewed from a fixed point on Earth, the satellite appears to have no kinetic energy, while the truck has significant kinetic energy. In a non-rotating reference frame, the truck's kinetic energy is approximately 844,000 Joules, while the satellite's is about 2.79 x 10^11 Joules. Thus, while the comparison highlights the vast difference in kinetic energy magnitudes, it is not straightforward due to the complexities of reference frames.
SarahM
Is the comparison of the kinetic energy of a satellite in orbit around the Earth to that of a truck traveling down a road realistic? Are they in the same reference frame?
It depends on how fast the truck is moving.
They are not in the same reference frame. They are both in an accelerating reference frame since they are both moving in a circle around the earth.
AM
That's actually an interesting question! Consider the situation when the truck is traveling down the road at 60 mph while the satellite is in geostationary orbit and you're observing from some comfortable perch that is fixed with respect to the Earth's surface. The satellite has no kinetic energy while the truck has quite a bit.
Clearly, there is something amiss with the comparison. To compare their kinetic energies properly you should use the same reference frame but the problem here is that the obvious reference frame (connected to the Earth's surface) is a rotating frame. Going to a nonrotating reference frame gives a very different picture.
Well the truck has a velocity of 0.0289km/s and a K.E of 0.844 kgkm^2/s^2 and the satellite a tangential velocity of 7.473 km/s and a K.E of 279249 kgkm^2/s^2.
I was trying to compare the two K.E values but wasnt sure if it was realistic to do so.
It is realistic only in the sense of giving you some appreciation of the magnitudes.
Incidentally, energy is usually expressed in Joules = kg m/s^2 so the truck has 844,000 Joules of KE while the satellite has 2.79 x 10^11 Joules of KE.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
