Refraction of light-apparent speed
  • Thread starter Thread starter irunwithmonkeys
    Refraction Speed
The discussion centers on calculating the apparent speed of an object moving in a liquid medium as observed from a medium with a different index of refraction. The indices of refraction are given as 1.2 for air and 1.47 for the liquid. The initial calculation using the formula v = c/n resulted in an apparent speed of 13.6 m/s, but clarification is needed regarding the application of the formula. The correct approach involves considering the relationship between real and apparent depths, leading to a different method for determining the apparent speed. The conversation emphasizes the importance of accurately applying the principles of refraction to solve the problem.
irunwithmonkeys
Imagine two media: one is thick air and the other is a liquid medium of some kind. The index of refraction of the air medium is 1.2
and that of the liquid medium is 1.47.
You are standing in the air medium looking straight into the liquid medium. You observe an object inside the liquid medium moving directly towards you. The speed of the object is 20 m/s. Assume the glass wall is very thin and that it doesn't affect the results. What is the apparent speed of the object as seen by you?
I used c = v/n so v = c/n
v=c/n= 20 [m/s] divided by 1.47 = 13.6 [m/s]
Can someone please help verify this is correct. Or am I doing this all wrong? Thank you very much for helping. I really appreciate it.
v=c/n= 20 [m/s] divided by 1.47 = 13.6 [m/s] In this formula v is the velocity of the light in the medium, not the object. If T and T' are the real and apparent depths in the liquid then you can wright 1.47/T = 1.2/T'. After 1 second real depth becomes T - 20 m and apparent depth will be T' - X. Find X
