What factors affect the refractive index of a medium?
In summary, refractive index is a measure of how light travels through a medium and it depends on both the speed of light and the wavelength of light. The equation n=c/v is used to calculate refractive index, but it is important to understand that the speed of light technically does not slow down in a medium. Instead, it takes longer for the light to pass through due to the thickness of the particles it must bounce through. This is known as dispersion and is why different wavelengths of light have different refractive indices. While it may be easier to think of the speed of light changing in calculations, it is important to keep in mind that our simplified models of physics may not represent the whole truth. It is beneficial to also consider the concept
adjacent
63
Refractive index depends on the speed of light traveling through that medium.It also depends on the wave length of light.If refractive index of water is 1.33,then for which wavelength is this?
Science news on Phys.org
If not otherwise stated, a refractive index is meant as an average for visible light.
Likes 2 people
But n=speed of light in vacuum/speed of light in the medium
The speed of light of all wavelengths is same.Then how can it vary(according to that equation)
That is true in vacuum, but not in media. In a medium, different wavelengths travel at different speeds (this is called dispersion), so different wavelengths get different refractive indices. This is why a prism splits white light into different colors, for example.
We all know that refractive index can be calculated with n=c/v and that the speed of light is
c=λf. To understand this question we need to see that light technically does not "slow down" when it passes through refractive areas. Instead it takes longer due to the thickness of the particles the light needs to bounce through. The variable v in n=c/v is just the measurement of the distance over the time that the light takes to pass through the area.
I know.but normally it's just used like that. :biggrin:
Light technically does slow down. What is the advantage of saying it doesn't?
I'm curious, is there any natural or intuitive way to think of dispersion in this picture? Why should blue light need a different number of bounces than red light, for example?
The advantage is that you don't have to explain how the light accelerates to c after leaving the medium.
Basically, ray diagrams and everyday experiences tell us that light travels in a straight line so you would need some kind of force at the interface. Or you could say that the light doesn't take a perfectly straight path on the microscopic level due to these bounces, so the average (net) speed decreases in the medium.
Actually it's much easier in calculations if we say speed of light changes(even if it doesn't),like the refractive index equation.If we are to account everything in a calculation,it would be impossible
Certainly! I'm not advocating that you should account for everything in calculations, but I am advocating to keep in mind that our simple models of physics aren't the whole truth.
One way of thinking of things may be advantageous for calculations, another less so. The first way doesn't even have to make sense, it could just be a heuristic for how to calculate things. But if the second picture is advantageous in that it makes different concepts and facts of physics consistent and hence possible to understand, it also has its value. In fact, it may be advantageous to think about the physics using that picture, and still doing the calculations in the simplified model.
That's hogwash. There is no "bouncing around". Light really slows down in a medium.
I think people need to understand what we mean when we talk about the "speed of light" in this context. There is a need here to really understand what is meant by the group velocity of light, such as when you send a light pulse out, either in vacuum or through a medium. What do you think is measured here when we try to detect the "speed" of this light?
Zz.
In the equation above, ##n = c/v_{ph}##, ##v_{ph}## is the phase speed.
Going along ZapperZ's point, to actually measure a speed, you have to send some kind of light pulse through the medium. Any light pulse will contain a broad spectrum of frequencies, and the pulse will come out very distorted on the other end of the medium. If there is a dominant frequency in the light pulse, then the phase velocity of the dominant frequency will be useful for calculating when most of the energy of the initial pulse gets to the detector.
I suppose the very front of the light pulse (defined as where the electromagnetic field is nonzero) will pass through the medium at a speed c, but this front will be severely attenuated. On the other end, the back of the pulse will be slowed way down, so the pulse is dispersed.
I should say that the speed of light depends upon the refractive index, rather than the way round you are putting it. The refractive index is a property of the medium. (Which will always very to some extent with wavelength - which is one reason that good camera lenses, with low chromatic aberration, cost an arm and a leg) The RI will be quoted for a particular wavelength, if it has been measured accurately enough to make a difference.
See the graph near the end of this link.
Maybe you can solve for the wavelength with the Sellmeier equation:
http:www.en.wikipedia.org/wiki/Sellmeier_equation
It is my understanding that blue light has a greater index of refraction than the other wavelengths because its frequency is closer to the natural resonant frequency of electrons in a material, violet to uv.
When light enters a medium the electric field causes the electrons in the material to oscillate proportional to the materials permittivity.
This oscillation of charges produces a wave of the same frequency but slightly out of phase with the original wave.
(The sum of these waves is a wave with the same frequency and a shorter wavelength causing a slowing of the wave).*
Permittivity is related to the dielectric constant.
n = c/v = √εμ
μ ≈ 1 for most materials in the light range
* If this is not correct, please correct. If it is correct can someone show how the sum of two waves of same
frequency slightly out of phase produces a wave with shorter wavelength. I thought only the
amplitude is affected.
http://www.mathpages.com/home/kmath210/kmath210.htm
see page 3of6
I also don't quite understand this discussion on the distinction between "true" speed of light and it's apparent value in a medium.
E.g. when you observe a supernova, are detected hours after the neutrinos due to their interaction with the interstelar medium. I think it would be strange not to say that they have a lower speed.
There is a very interesting calculation in Arnold Sommerfelds classic lectures on Optics.
I thought that the OP was just about the wavelength at which the refractive index is quoted. That velocity ratio is defined in terms of phase velocity and an endless wave train, afaik, which is what the simple Snell's Law diagram is based on. There seems to have been a bit of 'inflation' in the thread which risks confusing the guy with the simple question.
Related to What factors affect the refractive index of a medium?
1. What factors affect the refractive index of a material?
The refractive index of a material is affected by its chemical composition, density, temperature, and wavelength of light. These factors determine how much the material will bend light as it passes through.
2. How does temperature affect the refractive index?
As the temperature of a material increases, its molecules vibrate more vigorously, causing light to slow down and bend more. This results in a higher refractive index. The opposite is true for a decrease in temperature.
3. Does the refractive index change with different wavelengths of light?
Yes, the refractive index of a material varies with different wavelengths of light. This phenomenon is known as dispersion. Different colors of light have different wavelengths and therefore can be refracted at different angles by the same material.
4. How does the density of a material affect its refractive index?
The density of a material plays a significant role in determining its refractive index. Generally, materials with a higher density have a higher refractive index because the closely packed molecules cause more bending of light.
5. Can the refractive index of a material be manipulated?
Yes, the refractive index of a material can be manipulated by changing its chemical composition, density, or temperature. This is why different materials have different refractive indices and can be used for various purposes, such as lenses for glasses or prisms for splitting light.
  • Optics
  • Classical Physics
10K
  • Atomic and Condensed Matter
