Refrigerator- thermodynamics: how do i start?
The discussion focuses on applying Newton's Law of Cooling to analyze a heat pump system maintaining a building's temperature. It involves understanding the relationship between the temperatures of the building (TH) and the colder environment (TC), alongside the power consumption (W) of the heat pump. The equation provided illustrates how the building temperature can be expressed in terms of these variables. A participant mentions successfully solving the problem using the coefficient of performance, indicating a practical approach to the thermodynamic principles involved. The conversation highlights the application of thermodynamic concepts in real-world scenarios.
WoIfgang
Newton’s Law of Cooling.
A building is maintained at temperature TH with a reversible heat pump operating between the building and a colder environment at temperature TC < TH. The heat pump consumes electrical power at a constant rate W. The building also loses heat according to Newton’s law of cooling, that is, at a rate a(TH – TC) where a is constant. Show that the building temperature is maintained at temperature
TH = TC + dW/dt (1/2a) [1 + sqrt( 1 + 4aTC/(dW/dt) )]
Puzzled about how to start
Hi, solved it using the coefficient of performance.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
