Regarding the 1light year pole question
  • Thread starter Thread starter minijumbuk
    Pole Year
The discussion centers on the thought experiment of a one light-year-long pole and whether a push from one end would be seen instantaneously at the other end. Most participants agree that the push would not be instantaneous, as the force must travel the entire length of the pole, which takes time. One argument suggests that once the push occurs, the movement would be perceived instantaneously by the other person, but this is countered by the understanding that any deformation or signal travels at the speed of sound in the material, much slower than light. The conversation also touches on the misconception of "rigid rods" in physics, emphasizing that all solids are governed by electromagnetic forces and that communication or movement cannot exceed the speed of sound in the material. Ultimately, the consensus reinforces that faster-than-light communication using a rigid pole is impossible.
minijumbuk
this thread is about the 1 light year long pole question, the thread was closed...
the question was " if there was a pole that is 1 light year long...person A at one side and person B at another" if person A pushes the pole, does person B see it instanteously...
most people said that it would not be instanteous because impact would need to travel 1 light year in order to get to the other side...
HOWEVER i have one thing to point out...
matter only gets "pushed" when the force provided travels the whole length of the object...not individual atoms, in the molecular level.
i.e. it would take person A a long time to push the pole because he has to let the force to travel the length of the pole...however, once he pushes it...person B sees the pole move instantaneously...
tell me if I am wrong...i got this from a very trustworthy source :rolleyes:
Science news on Phys.org
There's probably a reason that thread was closed, and that your posts were deleted-- I'm sure you shouldn't start another thread on the exact same topic!
Could you link to your trustworthy source?
my source is from a teacher at james ruse, therefore i cannot link you to him...
Sounds like the teacher is struggling to explain the issue in a manner you understand. How about you provide your teacher with a link to this thread?
Either your teacher is oversimplifying it for you or doesn't understand it himself.
A push is the same as an impact.
mini
I thought of the very thing you are talking about a few years ago. I wanted to get around faster than light communication by constructing a rigid rod 1 l.y. long. Then an actuator on one end would strike the rod in a pattern like morse code, upon which the receiver could decipher the code and voila, faster than light communication.
My error, was that every time you strike the rod, the 'strike' is really just a tiny deformation made in the rod's end. This deformation travels along the rod at the speed of sound of the given material, in this case a metal rod. This speed is very slow compared to C and therefore it makes faster than light speed communication impossible for this scenario.
Even if you could strike the rod's end with an actuator that strikes it at the speed of light (which again, is impossible) the deformation of the rod would still be a bottleneck and no communication at the speed of light would be attained.
So, your idea is very clever, but its just impossible.
True. "Rigid rods" (where both ends would move at the same instant in time) are fairytale creatures that only live in school mechanics textbooks, not in the observable universe.
Yes I know, I made this point already.
If you ask someone who studies solid state physics (which I did), you'll get the answer that ALL of solids are held up together via electromagnetic forces. Now this may not mean anything to you and your "trustworthy source", but if both of you have studied any significant amount of classical electromagnetic theory, you will notice that light is also governed by such electromagnetic theory.
This means that the bonding that forms between atoms and molecules that causes a solid to hold its shape is nothing more than electromagnetic forces. Since light is electromagnetic in origin, the speed in which something can be transferred from one location to another in a solid is, at most, the speed of light. In fact, there's considerable evidence that it is significantly smaller than the speed of light because what is being transferred isn't purely an electromagnetic signal, but rather, a vibration signal. This is slower because the vibraton is trying to move heavy ions that make up the material, and there will be a significant delay in time when one tries to move something heavy. That is why the speed of vibration transfer (the speed of sound) in the material is significantly less than the speed of light!
The last thread on this that was locked, I believe, because there were simply way too many speculative and outright wrong "explanations". People obviously either forgot, or did not pay attention to the PF Guidelines.
Zz.
Heck, you don't need even need to be a physicist for this - as an engineer, I see all beams, rods, etc. as essentially just very stiff springs.
