Regarding the Form of an Automorphism
  • Thread starter Thread starter e(ho0n3
    Form
e(ho0n3
[SOLVED] Regarding the Form of an Automorphism
I want to prove the following:
f : \mathbb{R}^n \rightarrow \mathbb{R}^n is an automorphism if and only if f has the form
\begin{pmatrix}x_1 \\ \vdots \\ x_n \end{pmatrix} \mapsto \begin{pmatrix} g_1(x_1, \ldots, x_n) \\ \vdots \\ g_n(x_1, \ldots, x_n) \end{pmatrix}
where
g_i(x_1, \ldots, x_n) = a_{i1}x_1 + \ldots + a_{in}x_n
and the a's are constants.
The attempt at a solution
Proving that f is an automorphism given that it has the latter form is easy. Proving the converse is hard.
It took me a while to prove the case for n = 1: For x not equal to 0, f(x)/x = f(x/x) = f(1) so f(x) = f(1)x. For x = 0, f(0) = f(0*0) = 0f(0) = f(1)0.
I was thinking about the 'n = 2' case. I can't employ the same method of proof as before since I'm dealing with vectors now. I'm thinking that the preservation of structure, i.e. f(u + v) = f(u) + f(v) and f(ru) = rf(u), must in some fashion force f to have the form described in the statement. However, I don't see how this could possibly be.
Try using the standard basis vectors for R^n.
In what way? I thought about u and f(u) as linear combinations of the basis vectors and the structure preserving properties. I didn't obtain further insight into the problem.
Perhaps another hint is in order.
Let {e1,...,en} be the standard basis of R^n, and let u1=f(e1),...,un=f(en). Then given x in R^n, with x=x1e1+...+xnen, we have f(x)=x1u1+...+xnun.
Ah, I see now. Man, I feel stupid for not being able to see that. Thanks a lot.
I wrote that thinking that it would be easy but as it turns out, it isn't. More specifically, showing that f preserves structure is easy:
Let
\vec{x} = \begin{pmatrix}x_1 \\ \hdots \\ x_n\end{pmatrix}
and
\vec{y} = \begin{pmatrix}y_1 \\ \hdots \\ y_n\end{pmatrix}
Let a and b be two scalars.
\begin{align*}f(a\vec{x} + b\vec{y}) &amp;= <br /> f\left(\begin{pmatrix}ax_1 + by_1 \\ \hdots \\ ax_n + by_n\end{pmatrix}\right) =<br /> \begin{pmatrix} g_1(ax_1 + by_1, \ldots, ax_n +by_n) \\ \vdots \\ g_n(ax_1 + by_1, \ldots, ax_n + by_n) \end{pmatrix} = <br /> \begin{pmatrix} ag_1(x_1, \ldots, x_n) + bg_1(y_1, \ldots, y_n) \\ \vdots \\ ag_n(x_1, \ldots, x_n) + bg_n(y_1, \ldots, y_n) \end{pmatrix}\\ &amp;= <br /> a\begin{pmatrix} g_1(x_1, \ldots, x_n) \\ \vdots \\ g_n(x_1, \ldots, x_n) \end{pmatrix} + b\begin{pmatrix} g_1(y_1, \ldots, yx_n) \\ \vdots \\ g_n(y_1, \ldots, y_n) \end{pmatrix} = <br /> af(\vec{x}) + bf(\vec{y})\end{align*}
Note that I've employed the fact that g_i is a homomorphism.
However, showing that f is bijective is hard:
To demonstrate that f is injective, suppose f(\vec{x}) = f(\vec{y}). Then f(\vec{x}) - f(\vec{y}) = \vec{0} which by the above implies that f(\vec{x} - \vec{y}) = \vec{0}. \vec{x} - \vec{y} could very well be \vec{0} since f(\vec{0}) = \vec{0}. However, there may be another vector \vec{v} \ne \vec{0} such that f(\vec{v}) = \vec{0}.
Another thing to notice is that f(\vec{x} - \vec{y}) = \vec{0} implies that
a_{i1}(x_1 - y_1) + \ldots + a_{in}(x_n - y_n) = 0
for i = 1, ..., n. This yields a homogeneous system of linear equations. Obviously, x_j = y_j is one solution. I don't know how to show that this is the only solution though.
Showing that f is surjective is just as difficult: Given a vector \vec{y} in the codomain, what vector \vec{x} satisfies \vec{y} = f(\vec{x})? I can write \vec{y} as a linear combination of the natural basis vectors, but then I would need to determine which vectors the basis vectors are the image of.
I wanted to comment on this earlier, but I assumed you just forgot to post that there were some conditions on the g_i. As it stands, the definition of f you're given does not guarantee that it will be an automorphism. For example if g_1 = g_2 = ... = g_n = 0, then certainly the g_i satisfy the requirements, and f(x)=0 for all x.
You're right.
I'm trying to think of a non-trivial map that is a linear transformation but is not an automorphism. So far I can't think of any. Perhaps all non-trivial linear transformations are automorphisms?
e(ho0n3 said:
You're right.
Any non-injective or non-surjective endomorphism is not an automorphism. For example, any projection onto a nontrivial proper subspace, e.g. project R^2 onto the x-axis.
Dang it. Why didn't I think of that. If f is given by
\binom{x}{y} \mapsto \binom{x}{0}
then f is a non-trivial linear transformation that is not injective and hence not an automorphism.
I will mark this thread as solved. Thanks everyone.
