Relating final speed of electron to its charge mass and voltage difference
The discussion focuses on deriving an expression for the final speed of electrons after passing through a voltage difference, specifically 120 kV. The initial equation presented is v = √(2QΔV/m), where Q is the charge of the electron and m is its mass. Participants emphasize the importance of unit conversions, particularly changing kV to V and ensuring charge is in coulombs to maintain consistency with energy units. Clarifications are made regarding the placement of mass in the equation, with a reminder that energy in joules relates to the base units of kilograms, meters, and seconds. The conversation concludes with encouragement and acknowledgment of progress in understanding the calculations.
franbella
Assuming that the speed of the electrons is zero as they are emitted from the filament and that as they reach the anode it is v, find an expression relating the final speed v to the charge on an electron, the mass of an electron and deltaV, and hence calculate the speed v of the electrons after passing through a voltage difference of 120 kV.
I'm new to this, but the equation I have come up with is
v = √ 2QΔV
m
I then get this:
√ 2 x (1.602 x 10-19J) x (120-0 x 103eV) = √ 3.8448 x 10-14
8.2 x 10-14 J 8.2 x 10-14 J
√0.46887804 = 0.6847466977
To two significant figures and in scientific notation this is 6.8 x 10-1 eV s-1
I think I'm tying myself in knots - please help!
You should divide by the mass under the square root, and do care about the units.
Sorry, my first post doesn't make it look like this because my m is not under the square root, but it should be - just an error with copy and paste. So I did do this, but I still feel lost. Is the equation I'm using applicable - the number's I've come up with don't seem right.
i noticed that in your original formula you put the m. What i meant was that when you put in the numbers i don't see you dividing by m.
v = √ 2QΔV
m
I then get this:
Little hard to see from post but remember to change kV into V and charge is in C. Therefore C x V = J, base units of J= kg m2 s-2.
kg m2 s-2
kg
= m2 s-2
square root of m2 s-2 = m s-1
Hope this helped.
Thank you - good reminder - I always forget. Think am getting somewhere now.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
11K
  • · Replies 25 ·
9K
