Relating limits to derivatives, as x approaches non zero number?
i_m_mimi
Suppose that f' (2) = 3. Find the limit as x approaches 2 of [f(x)−f(2)]/[sqrt(x) - sqrt(2)]
Answer: 6*sqrt 2
f'(x) = lim h->0 = [f(a +h) - f(a)]/h = slope [f(x)-f(2)]/ x-2
a = 2
i would think that the limit = 3? wrong answer
tried graphing it, but no original function is given
sqrtx and sqrt2 confuses me and not sure how to do it.
thank you
Answer: 6*sqrt 2
a = 2
thank you
Rationalize the denominator of ##\displaystyle \ \frac{f(x)−f(2)}{\sqrt{x\,}-\sqrt{2\,}}\ .##
Equivalently, write
\frac{f(x)- f(2)}{\sqrt{x}- \sqrt{2}}= \frac{f(x)- f(2)}{x- 2}\frac{x- 2}{\sqrt{x}- \sqrt{2}}
= \frac{f(x)- f(2)}{x- 2}\left(\frac{1}{\frac{\sqrt{x}- \sqrt{2}}{x- 2}}\right)<br /> <br /> \text{ and think about the derivatives of f(2) and }\sqrt{x} at x= 2.
Likes 1 person
HallsofIvy said:
Equivalently, write
I think I've got it :) how did you create those math symbols and format it that way? was it through the physicsforums website coding or by a program?
f'(2) = 3
x = 2
lim x->2 [f(x) - f(2)]/(x - 2) * lim x->2 1/ [sqrtx - sqrt2]/(x-2)
= (3) * 1/f'(sqrtx)
= 3 * 1/(1/2sqrtx)
= 3 * 2sqrtx
= 3 * 2 sqrt2
= 6 sqrt2
It's called ##\LaTeX## ;)
Underneath each post you will see a button marked "quote" - if you click on it, you will be taken to an advanced editor screen where everything in the post is included in "quote" tags. Read what is in the quote to see how all the symbols came out nicely formatted ;)
Use double-hash or double-dollar signs around the block of math you want formatted - and use a backslash "\" in front of the bits that need special formatting - so \sqrt{ \frac{\alpha}{\beta} } will come out $$\sqrt{\frac{\alpha}{\beta}}$$
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
