Relation Between Electric Frequency and magnetic field rotation speed in a motor
The discussion centers on the relationship between electric frequency and the rotation speed of the magnetic field in a motor. It explains that in a three-phase system, each phase corresponds to its own winding, which are physically spaced 120 degrees apart. This configuration leads to the creation of multiple poles when two sets of three-phase signals are used. The question arises about the behavior of the poles, specifically why one pole moves half the distance of the other. Visual aids, such as diagrams of three-phase windings, are suggested to enhance understanding of the concept.
Chacabucogod
Hi!
I understand that if you have a stator with a a three phase electric signal going into it, both the frqyency and angular velocity of the magnetic field and the electric entry will be the same. Now when you feed it with 2 groups of three phases electric signals you get four poles, or at least that is what the book says. Why does that happen. Why does one pole only go half the way and the other one the other half. I can't quite grasp that idea.
Thank you
Chaca, good question. But each of the three phases is in its own winding. The windings are 120 degrees apart physically (rotationally), too. It is not one winding. I have some stuff I used to teach around here somewhere, if you want help in visualization.
Likes dlgoff
That'd helpful! Thankyou
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
