Relation between work and change in energy.
The discussion clarifies that "change in energy" refers to the energy transferred to or from a system when work is done. Work is defined as the mechanical transfer of energy, which results in a change in the system's energy. Two primary types of mechanical energy are identified: potential energy and kinetic energy, with kinetic energy being the energy of motion. When a force is applied to an object, it accelerates, leading to a change in its kinetic energy, which work measures. Overall, work is expressed mathematically as the integral of the scalar product of force and distance covered.
Caraniah
I'm confuse... What does it mean by saying, " change in energy"? What energy? Please help me... and explain. And no, this is not my homework... I'm doing my notes for physics.
Work is the mechanical transfer of energy. If you do work on a system, you are transferring energy either to or from the system...with this, there is a change in energy of the system. There is potential energy and kinetic energy (two types of mechanical energy we will associate with for now classically). Kinetic energy is the energy of motion; when applying a force to an object, you are accelerating it, so you are changing its kinetic energy...this is what work measures: the change in mechanical energy...hence, work is an integral of the scalar product of force and distance covered.
If you're asking for a definition for energy...then it could get a bit complicated...
Thank u. Just exactly what i want...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
