TrickyDicky
- Messages
- 3,507
- Reaction score
- 28
Actually I see Dalespam already mentioned ROS in #26.
Quite agree TrickyDicky and more succinctly expressed than myself, but (and it won't be real soon from me) looks like some convincing calculations will be in order, to prove it one way or the other. One thing I am almost 100% certain about is that length contraction of the moving loop in frame S' does not capture the non-simultaneity relevant here - those clocks on the periphery will be quite out of sync in S' notwithstanding the squashed shape of loop they ride on. Also, the circulation of E must be an intrinsic, intensive feature, not some effective internal field arising from any special material interactions in the loop conductor. Hence a Feynman disk or similar will rotate in response to an intrinsic curl E no differently than a current will circulate in a conducting loop - with the conceivable caveat that induced surface charges are negligible; well satisfied for a very thin loop. Must go.TrickyDicky said:It is IMHO as Q-reeus says, a paradox that is fully solved by the relativity of simultaneity set in Minkowski spacetime.
Just like two spacelike separated observers may not agree about the causality of certain events, if we consider the loop as spatially extended, two observers may disagree about what happens, that is because in relativity only spacetime is well defined, not the space slice.
Q-reeus said:Quite agree TrickyDicky and more succinctly expressed than myself, but (and it won't be real soon from me) looks like some convincing calculations will be in order, to prove it one way or the other. One thing I am almost 100% certain about is that length contraction of the moving loop in frame S' does not capture the non-simultaneity relevant here - those clocks on the periphery will be quite out of sync in S' notwithstanding the squashed shape of loop they ride on. Also, the circulation of E must be an intrinsic, intensive feature, not some effective internal field arising from any special material interactions in the loop conductor. Hence a Feynman disk or similar will rotate in response to an intrinsic curl E no differently than a current will circulate in a conducting loop - with the conceivable caveat that induced surface charges are negligible; well satisfied for a very thin loop. Must go.
