Relative Velocities with angles
  • Thread starter Thread starter Jtappan
    Angles Relative
To determine the direction the dolphin should head to swim directly back to its home bay, the problem involves calculating the resultant velocities of both the dolphin and the water current. The water current flows southeast at 2.93 m/s, which is at a 45-degree angle, affecting the dolphin's swimming direction. The dolphin's velocity relative to the water is 4.14 m/s, and its horizontal and vertical components must be analyzed to find the angle needed to counteract the current. The discussion highlights the need to set up equations for the horizontal and vertical components of both velocities to solve for the angle and the time it takes to cover the distance of 0.79 km. Ultimately, the problem requires a careful balance of vector components to find the correct heading and travel time.
Jtappan
A dolphin wants to swim directly back to its home bay, which is 0.79 km due west. It can swim at a speed of 4.14 m/s relative to the water, but a uniform water current flows with speed 2.93 m/s in the southeast direction.
(a) What direction should the dolphin head?
_______° N of W
(b) How long does it take the dolphin to swim the 0.79-km distance home?
________min
First I have been trying to find all of my variables in both directions. The angle should be 45 degrees for the 2.93m/s in the south east directions, I am pretty sure. Then I am just completely lost after that. If it is a 45 degree angle then you do 2.93sin45 and get 2.07 roughly. This is where it loses me because there are two different velocities for the Dolphin relative to the water.
Let theta be the angle of the dolphin's velocity from the positive east axis...
So the dolphin goes 4.41cos(theta) in the horizontal direction...
He goes 4.41sin(theta) in the vertical direction.
What is the horizontal and vertical component of the water...
What can you say about the sum of the vertical component of the water + the vertical component of the dolphin's velocity? That should let you get theta... also note, theta should be bigger than 90 degrees... because the dolphin needs to go west...
