Relativist Addition of Velocities
  • Thread starter Thread starter jgens
    Addition
The discussion centers on the relativistic addition of velocities, specifically examining how the velocity of a particle changes when observed from a different inertial frame. The user is attempting to derive the expression for the magnitude of the particle's velocity in the moving frame, given the original velocity and the frame's velocity. They have set up the equations but are struggling to simplify the expression for |\mathbf{u}'|^2 effectively. A suggestion is made to first prove the case where |\mathbf{u}| = c, which may provide insights into the more complex scenarios. The conversation emphasizes the importance of understanding the relativistic framework to resolve the velocity transformation.
jgens
Fix an inertial reference frame and consider a particle moving with velocity \mathbf{u} in this frame. Let \mathbf{u'} denote the velocity of the particle as measured in an inertial frame moving at velocity \mathbf{v} with respect to the original frame. Show the following:
  • If |\mathbf{u}| < c, then |\mathbf{u}'| < c.
  • If |\mathbf{u}| = c, then |\mathbf{u}'| = c.
  • If |\mathbf{u}| > c, then |\mathbf{u}'| > c.
N/A
By choosing coordinates appropriately, it suffices to assume that \mathbf{v} is directed along the x-axis of the original frame, so write \mathbf{v} = v. Now write \mathbf{u} = (u_x,u_y,u_z) and \mathbf{u}' = (u_x',u_y',u_z') and recall that the relativistic addition of velocities implies:
<br /> u_x&#039; = \frac{u_x-v}{1-\frac{vu_x}{c^2}} \;\;\; \mathrm{and} \;\;\; u_y&#039; = \frac{u_y}{1-\frac{vu_x}{c^2}}\sqrt{1-\frac{v^2}{c^2}} \;\;\; \mathrm{and} \;\;\; u_z&#039; = \frac{u_z}{1-\frac{vu_x}{c^2}}\sqrt{1-\frac{v^2}{c^2}}<br />
These three equalities should allow for the computation of |\mathbf{u}&#039;| in terms of the known speeds |\mathbf{u}| and |\mathbf{v}|, but for whatever reason, I am having difficulty simplifying the expression below to a useful point:
<br /> |\mathbf{u}&#039;|^2 = \left( \frac{u_x - v}{1 - \frac{vu_x}{c^2}} \right)^2 + \left( \frac{u_y}{1-\frac{v u_x}{c^2}} \sqrt{1-\frac{v^2}{c^2}} \right)^2+ \left( \frac{u_z}{1 -\frac{vu_x}{c^2}} \sqrt{1-\frac{v^2}{c^2}} \right)^2 = \left( \frac{1}{1 - \frac{vu_x}{c^2}} \right)^2 \left[ (u_x-v)^2 + u_y^2\left(1 - \frac{v^2}{c^2}\right) + u_z^2\left(1 - \frac{v^2}{c^2}\right) \right]<br />
Does anyone have some suggestion how to simplify that any further in a useful direction?
hi jgens! :smile:
try proving it for the easy |u| = c case first :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
