Relativistic electrical varialbes
bgq
Hi,
1) How does the electric circuit variables such as Voltage, Electric current, and Resistance vary between two frame of references?
2) Based on (1): If someday we build a spaceship that move with very high speeds, are there issues to consider regarding the electric circuits in the ship?
https://www.physicsforums.com/showthread.php?t=631446#post4049887 might be of some interest, in that it shows a relativistic boost of a current loop. I'm not sure how clear it will be unless you're already familiar with the Loretnz transform and the charge-current 4 vector.
Of course, there won't be any impact from any of this on a spaceship that moves at very high speeds -this follows directly from the principle of relativity. If there was any such effect, you could distinguish "rapidly moving" spaceships from "stationary" ones in an absolute sense. Relativity prohibits this, and thus even a rapidly moving spaceship won't see anything different as far as the laws of physics go. In fact, there are probably a number of observers that regard you as rapidly moving, right now.
bgq said:
Hi,
This is a very important topic which didn't get much attention
as did 'twin paradoxes'. If speed affects length and time, and current is dependent on time,
detailed analysis may show breakdown of Ohm's law on the ship as seen from earth.
But Ohm's law will be obeyed as seen by an observer on the ship.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
