Relativistic kinetic energy - particle decay
A pion at rest decays into a muon and an antineutrino, prompting a calculation of the muon's kinetic energy and the antineutrino's energy. The initial attempt assumed the antineutrino's energy to be negligible, leading to a calculated kinetic energy of approximately 33.7 MeV, which contradicts the book's answer of 4.08 MeV. The discussion highlights the importance of conservation laws, particularly momentum conservation, in particle decay scenarios. It emphasizes that in two-body decays, the lighter particle (the muon) carries most of the kinetic energy. Accurate calculations must consider the relationships between momentum and energy, even for massless particles like the antineutrino.
Phynos
A pion at rest (mπ = 273me) decays into a muon (mμ = 207me) and an antineutrino (mn ≈ 0).
Find (a) the kinetic energy of the muon and (b) the energy of the antineutrino in electron volts.
K = (γ-1)mc2
E = γmc2
ER = mc2
E2 = p2c2 + (mc2)2
I didn't use all of these, but I'm assuming a solution requires one or more of them.
Not really sure how to go about this when the mass of the neutrino is so close to zero. If I assume the total energy after the reaction of the neutrino is essentially zero, then the missing energy goes into the motion of the muon.
Kμ ≈ E - E
= c2 (mπ - mμ)
= c2 (0.511*106eV/c2)(273-207)
= 3.37*107 eV
= 33.7 MeV
The answer in the book is 4.08MeV so either my assumption that Kn ≈ 0 is a bad one, or I've made a mistake somewhere here.
Yes, your assumption is bad. In fact, in a two body decay, the lighter decay product will carry most of the kinetic energy.
You need to fulfill the conservation laws involved, which are they?
So momentum needs to be conserved, however the momentum is proportional to mass just like kinetic energy, which is what lead me to conclude the kinetic energy must be close to zero. How do I go about calculating the momentum of something for which I do not know the mass?
Momentum is only proportional to mass for fixed velocity < c. You can only draw the conclusion that a light particle has smaller energy or momentum than a heavy if they have the same speed.
You already have a relation between the momentum and total energy of a particle. This relation is true also for massless particles.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
