Relativistic Rocket: Find Δv in Earth Frame
To determine the increase in speed of a rocket accelerating at 9.81 m/s² from Earth's frame of reference, the relativistic velocity addition formula must be applied. The rocket's instantaneous speed increase is calculated using proper time, but adjustments are necessary for the Earth frame. The formula presented, Δv=9.81*Δt/sqrt(1+9.81*Δt/c²), needs clarification on the variables involved. Properly identifying v, u, and v' in the context of the problem is crucial for accurate calculations. Understanding these concepts will enable the correct application of the relativistic velocity addition formula.
Hebrew21
I a little lost on how to use the relativistic velocity addition formula to determine the increase in speed "v" over a short time interval in the Earths frame of reference, for a rocket having left Earth at rest and traveling through space accelerating at constant acc. of 9.81 m/s^2. In the rockets instantaneous frame of reference, the increase in speed is (9.81m/s^2)*Δt where Δt is the proper time interval. The equation must be modified to determine a speed increase Δv over a short interval of time from the Earth frame of reference. I guess the question I have is if I can use this formula to solve for the change in velocity over a small interval of time, for a different reference frame?
v=u+v'/ sqrt(1+v'u/c^2)
Here's what I have so far, not sure if its close:
Δv=9.81*Δt/sqrt(1+9.81*Δt/c^2)
You should review the velocity-addition formula. Identify what v, u, and v' stand for as it relates to this particular problem, and then try again.
