I Relativity and speed of light basics
starstruck_
I decided to read up on the chapters we didn’t cover in first year Physics from my textbook, and decided to start with general relativity since it was in the same section of the textbook as the last topic we covered (that topic was physical optics - not lenses- photons and the double slit experiment and so on).
I 100% do not understand the whole speed of light light portion of it// why all observers observe it at the same speed.
From previous knowledge, I know that the velocities we have dealt with were relative to something. If we were moving within our frame of reference then the velocities would change accordingly.
Light doesn’t follow that. No matter whether the observer is moving or not, the speed of light remains constant in a constant medium.
So does that mean that the speed of light is relative to the medium it is traveling through and not to objects traveling to or away from a source of light? ((I think I’m understanding this wrong))
Also does it have anything to do with the amount of medium between the object and the light source.
If the speed of light depends on the medium it is traveling through, then only a certain number of photons could exist within a given volume of the medium at a certain time, right? Or is that wrong?
If a car is moving toward the light source, then the amount of medium between the light source and car is reduced but so is the number of photons there so the light that is still approaching the car would be approaching it at a constant speed?
I don’t really know what I’m talking about, I’m just trying to make sense of this. I watched a video on it that seemed helpful but I’m a little slow so it hasn’t made any sense.
If someone could explain this from scratch (sorry if it’s asking for a lot) that would be extremely helpful!
Just so you are aware of it, this is not General Relativity, this is Spacial Relativity.
Zz.
Likes PeroK and FactChecker
This is the expectation from classical mechanics and its corresponding Galilei transformations. (Also note, you are not moving "within your reference frame". The more correct statement would be that you are moving relative to some reference frame.) That does not mean that it must be correct and in fact it is not what is observed for light.
There is no medium. The statement that the speed of light is invariant is in regards to the speed of light in vacuum. If you have a medium, then there will be a certain drag coefficient. One of the deeper insights from SR is that there need not be a medium for light to propagate, which led to the idea of a luminiferous aether being scrapped.
Again, there is no medium
I don't know where you got that from. It is certainly wrong. I also strongly suggest that you leave photons out of it for the time being. It is not worth thinking about photons unless you start doing quantum field theory.
Unless you tell us which video you watched, how are we to know what you saw or whether the problem is in your interpretation or in the video itself? Please provide appropriate references.
Explaining from scratch would entail effectively writing a textbook on relativity. This has already been done and there are several good textbooks available. It is not what forums are for. If you have specific questions regarding what you read in those textbooks, please feel free to ask for clarification.
Likes FactChecker
There isn't an answer to any of the "why" questions that people ask about Science. Without going into details , all we can say is that assuming the invariant speed of light fits the evidence of experiments (not under normal conditions).
Try this link and avoid skipping too much. It could help. It is not intuitive stuff, remember.
Likes Mr Wolf and FactChecker
The speed of light in vacuum is the same for all observers. The speed of light in a medium is not. You should concentrate on the vacuum case because it's much easier and you have to understand it before you can take on the more complicated problem of the behavior of light in a medium.
If A and B are moving relative to one another, then A can consider himself to be at rest while B is moving relative to him, or the other way around. Thus, any time that you say something is moving, you have to say what it is moving relative to. But no matter who you consider to be at rest, the speed of light in a vacuum will be the same relative to that observer.
I don’t think that there is a good reason why for this in science. (Science is notoriously bad at answering why questions). Relativity does not explain why c is invariant. Instead, it assumes that c is invariant and examines the consequences of that assumption. All of the famous relativistic effects are the result of making that assumption.
@starstruck_ - Maxwell's equations predicted an invariant speed of light in vacuum. That is, the speed of light was always the same, no matter what the emitter or the observer was doing. This was obviously daft, and much of physics in the latter half of the 19th century boils down to trying to spot the problem with Maxwell's work. Presumably it was a special case of something.
This turned out to be completely wrong. Einstein simply took this daft idea that light always moves at the same speed and worked out the consequences if he assumed it was right. That's special relativity, in a nutshell. All the equations reduce to familiar Newtonian forms when everything is moving much slower than light, but that means Newton is the low-speed limit of a more general theory.
The important difference between the two is that relativity doesn't have an absolute notion of time. If we are moving relative to one another we will both determine that the other's clock is ticking slowly, and we will both determine that clocks on the front of the other's vehicle are out of sync with clocks on the rear (note I'm carefully saying "determine" because I'm assuming we're both smart enough to correct what we see for the travel time of light). The first concept (time dilation) is quite famous, but the latter (relativity of simultaneity) is probably more important to get your head around.
That's a very brief intro. It is extremely counter intuitive. May I ask what textbook you are looking at?
Yes, and that is wrong.
Let's consider Bob, who is swinging in a swing, and Alice who is traveling at speed 0.87 c relative to Bob (I mean relative to the ground that the swing is standing on). Swing's maximum speed relative to ground is 0.5 m/s. So ground's delta v according to Bob is 1m/s.
Oh yes, Bob is swinging along the x-coordinate and Alice is moving along the x-coordinate.
Now we want to calculate how much Alice's speed is changing according to Bob.
First let's calculate how much Bob's speed changes according to Alice: Answer is 0.25 m/s. (Because in Alice's frame Bob is swinging at half rate,compared to Bob's frame, and the swinging distance is halved too, compared to Bob's frame)
So Alice's speed changes by 0.25 m/s according to Bob, because Bob and Alice always agree about their relative speed.
Zz.
Ohh sorry, didn’t know, I was assuming this might be a part of a second year course.
Okay so the medium isn’t a part of this, this only has to do with the speed of light in a vacuum and working under that assumption?
Also, sorry, the video didn’t explain the speed of light//observing question I had, it explained time dilation which didn’t answer my question. I was just trying to understand why, please ignore that gibberish.
This is the video:
I understood the time dilation part. It was just the question I had about observing the speed of light part but I guess, looking at other answers, there is no answer to that question.
Well, if light has a constant speed in one frame, then time dilation would insure that it also has the same constant speed in every frame. That's sort of the reverse of the usual logic, which derives time dilation from the constancy of the speed of light.
Likes Dale
Sorry, I’m probably uh understanding this wrong ((again)), so we’re just going backwards and saying that since time dilation is a thing and the time observed for either observer is different, the speed of light is constant?
We are not mixing the chicken and the egg.
Time dilation concept is a consequence of light having the same speed in all inertial reference frame, not the other way around.
Zz.
Zz.
Well, if light has a constant speed in one frame, then you'll have time dilation for light clocks that are moving with respect to that frame. For light clocks, you don't need to assume that light has the same speed in every frame. Of course, you don't get (without further assumptions) that every physical process experiences the same time dilation.
Actually, to get time dilation for light clocks, you need to assume something about how lengths transform between frames. So I guess time dilation doesn't just pop out.
But SR did not start with "time dilation".
We all need to go back to the SR postulates, which are the starting point of SR.
https://www.nobelprize.org/educational/physics/relativity/postulates-1.html
Without those postulates, we do not have SR. Time dilation is a consistent outcome of the postulate that c is a constant in all inertial frame. Otherwise, we will be doing Galilean transformation.
Zz.
It's just a way to construct a theory through logical reasoning. We can also start with space-time with certain properties and derive everything from there (including the constancy of the speed of light). It doesn't matter. What matters is the resulting theory and its logical consistency, non-self-contradictiveness (is that a word?). Time dilation and light-speed invariance are both part of it at the same time.
Actually, for science, what matters the most is that it matches experimental observations. A theory can be as logically consistent and esoterically beautiful, but it is useless if it doesn't match empirical evidence. History of physics is littered with such theories that failed this criteria.
Zz.
Which textbook is this? Title and author(s)? Someone here might actually be acquainted with it or have a copy, and can help with specific rough spots in it.
Likes Ibix
For me, the most convincing way to "derive" SR is to investigate all spacetimes which obey the special principle of relativity (existence of a class of global inertial frames) and that any inertial observer finds space to be described as a Euclidean affine manifold. From these assumptions you get two basic kinds of spacetime, the Galilei-Newton spacetime underlying Newtonian physics (no limiting speed) and Einstein-Minkowski spacetime underlying special relativistic physics (with limiting speed). Which one of the two possibilities describes the observations better (approximately of course) is then a matter of empirical validation, and it's very clear that the special-relativistic description is way better than the Newtonian one, which is however valid as an approximation for low speeds and accelerations. SR itself is also only approximate, because as soon as gravity becomes important (which due to its weakness is only rarely the case in some sense, which is why we can deal very well with Newtonian physics in everyday life) one has to take into account general-relativistic spacetime.
Likes Dragon27
Don't focus on light. Focus on a speed. There's a speed that's the same regardless of the state of motion of an observer. It's just that we believe light travels at this speed, but even if it didn't nothing would change, there would still be a speed that's the same for all observers.
Philosophically you can ask why this is true, but all we can really do in the way of a response is to look at the implications of it. And then look at Nature to see if it behaves in a way that's consistent with it.
Lots of books have been written explaining special relativity. Find one you like and read it. It's a much more satisfying experience than asking to have it explained. Of course, if you get stuck on something come here to ask about it. That's the best way to do it.
Likes starstruck_
Yes, of course, though I was talking specifically about that.
You just stated the basic idea correctly, that the speed of light is constant for all observers. So your difficulty isn't as simple as not understanding it, it's that you're resisting the idea for some reason. It may be as simple a reason as "this isn't the way things used to work", or there may be more subtle reasons why you're resisting the idea.
Your musings about a medium do not seem to be part of the textbook. I would guess that they are a part of you resisting the idea that the speed of light is constant for all observers.
IT's not clear at this point why you are resisting the idea so strongly - it could be as simple as that it's a new idea, but it's probably more complicated than than that. There are many possible sources for your resistance, most of them are common, but they aren't necessarily exactly the same from person to person, so it's hard to guess what they might be in order to address them. There are some common stumbling blocks, it's not clear if you've gone far enough down the road of understanding relativity to stumble over them yet, though.
The main point I want to make is that you seem to understand the basic idea OK (before you start to try to distract yourself with personal musings about a medium, at least). You just don't want to accept it - not even on a provisional basis, which is at this point is all that's required, a very provisional acceptance and a willingness to explore the logical consequences of this strange assumption.
As for the "why" of it all, it boils down to "because it matches observations". At some point you can eventually start looking at some of the experiments that relativity explains, and that classical mechanics does not, such as the Michelson-Morley experiment.
Likes PeroK
Erribert: I have gone through the derivations of both special and general relativity and too have some questions. Since this is special relativity, I will continue with where you left off. Einnstein’s Second Postulate (since he provides no references in his paper) is that the speed of light is constant in a vacuum. Einstein did not have access to satellite data we have today.
According to articles I have read from NASA and others, there appears to be a lot of plasma in our solar system. There is also “dust”. Could these act as mediums? If so, wouldn’t the speed of light vary.
I am far from well educated in this, and am not a physics experimentalist in this area. What would be the impact of plasma, solar winds, and dust on the speed of light. Why did Einstein like the idea of it being constant? Have experiments in earthly laboratories confirmed this?
Cheers
The invariance of the speed of light in vacuum was a prediction of Maxwell's equations, and is incompatible with Newtonian mechanics. Everyone was trying to fix Maxwell's equations to be consistent with Newton; Einstein had the idea of replacing Newton with something consistent with Maxwell.
Likes Sorcerer and m4r35n357
Actually, this isn't true.
Maxwell equation gives "c", but it doesn't tell you that it is invariant. In fact, Maxwell equations at that time were not invariant under Galilean transformation, and that was the impetus for Einstein to come with SR.
Zz.
I thought it was Lorentz who came up with the theory through his Lorentz Transformations that keep the wave equation invariant.
  • #31
As Ibix has pointed out, the transformation was known, but Lorenz was trying to force light and EM to behave in a Newtonian way. These attempts were getting quite silly towards the end, so I'm not surprised that Einstein didn't refer to their work ;)
  • #32
ZapperZ said:
Actually, this isn't true. Maxwell equation gives "c", but it doesn't tell you that it is invariant.
You also need the assertion that all inertial reference frames are equivalent. That, combined with Maxwell's electromagnetism, gives you invariance of the speed of light. It was Einstein who demonstrated this. Lorentz didn't.
  • #33
My rather blunt understanding is that Galilean thinking was local principles of mechanics would look the same to each individual inertial observer, Maxwellian thinking was that local principles of electromagnetism would look the same for each individual inertial observer, and that Einstein was perhaps the first to realize a choice needed to be made in order to avoid a paradox when attempting to make these local principles look the same when distributed among all possible inertial observers... the dilemma being that either the principles will look different for different inertial observers, or that the principles will look the same for all inertial observers if time, space, and simultaneity are allowed to do something new. This latter choice assumes constant c for all inertial observers and the "something new" being special relativity with all it's consequences.
  • #34
Perhaps you would find that the principle of relativity, the laws of physics are the same in all inertial frames of reference, is easier to swallow than the constancy of the speed of light. Maxwell's equations predict the speed of light in a vacuum to be c≈3x108 m/s in my laboratory and I have done every experiment I can think of to verify that Maxwell's equations are correct. Maxwell's equations are laws of physics. Therefore the laws of electromagnetism, including the speed of light, will be the same in any other inertial reference frame. In other words, the constancy of c is a necessary consequence of the principle of relativity.
  • #35
This does not logically follow. For example, Maxwell's equations could be the manifestation of the laws of physics in the rest frame of a medium, let us call it aether, where the speed is the same in all directions much like sound waves have the same speed in all directions in the sound medium's rest frame but not in a frame where it is moving. Of course, you then end up with trying to measure your movement relative to the aether and will be surprised to find that you are in the aether rest frame. People tried to do this for a long time before a more elegant solution was suggested, that the reason that we find the speed of light being the same in all directions is that the speed of light indeed the same in all directions in all frames and that there is no need for a medium.
  • #36
It's not a choice. Both must be swallowed. Contrary to what you seem to be claiming, the latter is not a consequence of the former.
So are Newton's. Einstein found a way to make it possible for both Maxwell's Equations and the Principle of Relativity to be valid.
Yes, experimental evidence confirms, as you pointed out, that Einstein got it right. But his logic requires both postulates.
Likes Orodruin
  • #37
It’s University Physics Volume 2 (Richard Wolfson)
  • #38
I'm not sure how everyone was taught SR, but it may be useful (especially for those who did not have a formal introduction to it) to once again go back to the very beginning and show the issue mathematically.
This document here shows things explicitly that leaves no doubt of the issue that was faced before SR:
https://www1.maths.leeds.ac.uk/~serguei/teaching/gr.pdf
There are two important points that are relevant to this discussion:
1. Newton laws are invariant under Galilean transformation (Section 1.5). This is crucial because it means that our laws of physics are the same in any inertial reference frame.
2. The original Maxwell Equations are NOT invariant under Galilean transformation (Section 1.8.5). This means that the speed of light is different in different inertial frame from the source.
So by the beginning of the 1900, this was a major conundrum in physics because #1 and #2 are incompatible with each other. This problem was well-known by most physicists at that time, and this was the impetus for Einstein to think about the problem that led to the postulate of SR and SR theory itself.
Zz.
  • #39
the postulate is that light is constant for all observers. But, do scientist ever talk about how light actually travels versus the observed behavior? My point is that you can't actually watch a photon travel through space. the only way to observe light is either with your eyes or an artificial detector. But, the light you observe, can be distorted in many ways (such as red shift, gravitational lensing etc.).
My understanding is that light propagates through the universe at a constant speed. But, unless light can be at multiple places at the same time, it has to actually be at a certain location at any given time (even though nothing is observing it). This brings me to my question; if you are traveling at realistic velocities, can the relative speed between you and photons of light be less or greater then C even though you will still "observe" light to be going exactly C (due to distortions in time and space)?
  • #40
This last part makes no sense. What makes you KNOW that you are traveling at "realistic velocities"? With respect to WHAT?
If you somehow are experiencing "distortions in time and space" while another observer does not, then there is something different about one inertial reference frame versus another, and this not only will run counter to SR, but also to Newtonian mechannics!
Zz.
  • #41
I think you have misunderstood what "observer" means in this context. It is not necessarily connected to someone actually watching the light as much as it is related to how the light behaves in different inertial frames.
  • #42
About "seeing light"... the mean free path of light within the aqueous and vitreous humor of the eyeball is very short - the light that reaches your retina is "brand new fresh" emitted/scattered light from immediately in front of the retina... at standard pressure and temperature at sea level the mean free path of light in air is about 15 meters...
About your last question... I think "relative speed between you and photons" depends on whether this speed is being noticed by you or by another... you will always measure it as c if you are inertial, but your closing velocity measured with respect to those photons by another but also inertial other may be c +/- some value, even as it is constant c to you.
  • #43
Are you asking if scientists ever talk about how light actually behaves versus the way it's observed to behave? Science is based on observations, I don't understand what the adjective "actually" implies in this context.
  • #44
Maybe a distinction between "observe" and "measure" would help here...
A scientist may observe that a light is red, and measure its frequency. He will talk about the light's frequency as one of its "actual" characteristics/behaviors, but not of the phenomenological quale of its red appearance to his observation as some "actual" property of the light itself, right?
  • #45
No. You cannot make a distinction. They are typically synonymous.
Light does not have a frequency on its own. The frequency is a property of the light-observer system.
Likes PeroK
  • #46
A measurement is an observation.
  • #47
I am sorry if I wasn’t clear, but my issue is that the universe has to exist whether it is being observed or not. Unless we are living in a simulation and things only exist when we observe them... anyways, photons have to propagate through the universe some how. They travel at the speed of light after all and follow straight paths, which can be bent by gravitational forces etc. but, at any given time a particular photon has to be somewhere in the universe at a given time, unless it can be in multiple locations at the same time.
Now, if oberservers are moving at realistic velocities relative to each other they will both measure the same speed of light due to the warping of space and time predicted by SR. My thinking is that SR is more of an optical illusion rather than actual changes to the universe around you. The photon of light doesn’t care how you move about the universe, it will follow its set path regardless. However, your relative velocities will change how you perceive said photon. It is you that is changing, not the photon.
Another example is that if we observe a spacecraft moving at realistic velocities compared to us, then it appear contracted along it length. However, that spaceship sees the universe as contracted along its length including us. Obviously, we can’t both be length contracted at the same time. Which makes me think it is more of an illusion rather than a physical change.
  • #48
Again, you have misunderstood the meaning ascribed to ”observer”.
I strongly suggest you stop thinking of photons as little balls of light. In fact, photons do not have a well defined position operator. Also, the question of what ”really” is is not a physics question, it is purely philosophical.
I am sorry, but your posts make it painfully clear that you have gotten the wrong notion about what length contraction is and relativity in general. There is no ”warping of spacetime” in SR and regerdless of what observer’s rest frame you use you are describing the same physical situation - just using a different set of coordinates.
  • #49
I'm not sure, what all of this means, but just for your information: the effects of SR are not optical illusion, when we say that an observer observes (or "sees") something, it is usually meant than an observer has already taken into account the way he obtained information (like, for example, if I see an object with my eyes, I should take into account the finite speed of light, and the time it takes for it to reach my eyes, and realize that the object "now" isn't there, because it moved forward, and what I see with my eyes has happened in the past), and reconstructed the positions and speeds of all the relevant objects in his frame of reference. And still he observes the counter-intuitive SR effects.
No, it's a real effect. One can easily see that after having studied and understood SR properly. But it is an "illusion" in a sense, in that the object doesn't actually changes, for example, if you suddenly started to move relatively to it, but your frame of reference, your hyperplane of simultaneity and perception of time and space in this new frame of reference change so that the object length is perceived differently. But the object's proper length (in his own frame) stays the same.
You say "we can’t both be length contracted at the same time". But it's not "at the same time", there's no logical contradiction here. Two different observers don't even have the same "the same time" (relativity of simultaneity)! Each one is looking at the other from a different frame of reference. Each observer has his own clocks and rulers. Obviously, they don't have to agree on their measurements.
All of that misunderstanding and confusion is easily resolvable by properly studying of SR and actually getting it, believe me. But you won't get it, if you keep asking malformed questions and refuse to go out of your "box" of thinking. You should get a good textbook and work through it.
I myself only started actually understanding SR when I saw how the 4-dimensional Minkowski space-time works. Looking at the basic effects (length contraction, time dilation, relativity of simultaneity) just didn't do it for me (although I was able to use them to calculate and even resolve some paradoxes). The 4-dimensional picture made everything click.
Likes weirdoguy
  • #50
@Orodruin the basic principal of SR is that the speed of light is intrinsic. All observes measure the same speed of light. Time dilation and length contraction are the way this happens. If there was no time dilation nor length contraction, then the observes would not be measuring the same speed of light. Observed and measure are just that. You only get the end result. The photon isn’t going to tell you all the distortions that it underwent on its way from its source to your instrument. SR is only going to tell you what the end result is, the measured quantity.
@Dragon27 you need to understand that SR is just a model that given information X Y Z you can make a prediction that matches reality. The only information you need to know about the objects velocities are their relative ones. There are an infinite number of combinations of actual velocities that result in the same relative velocity and will all have the same result. There is no universal observer in SR, but you could set any object in the universe as a universal observer if you wanted to and it would have no effect on your predictions, only make it more complicated.
