Relativity: Comparing Clocks in Different Frames
  • Thread starter Thread starter DWill
    Relativity
The discussion centers on understanding time dilation in different inertial frames as described by the theory of relativity. In the first scenario, the observer gliding over Earth concludes that clocks X and Y, which are stationary relative to Earth, appear to advance slower than their own clock, and when passing clock Y, it reads an earlier time. In the second scenario, the observer floating in space sees the clock of the flying saucer advancing faster than their own wristwatch, while the space alien perceives the observer's watch as advancing slower. Clarifications emphasize that an inertial observer always regards other clocks as running slower, regardless of their frame of reference. The conversation highlights the complexity of determining which frame is inertial and how time is perceived differently based on relative motion.
DWill
1) You are gliding over Earth's surface at a high speed, carrying your high-precision clock. At points X and Y on the ground are similar clocks, synchronized in the ground frame of reference. As you pass over clock X, it and your clock both read 0. (a) According to you, do clocks X and Y advance slower or faster than yours? (b) When you pass over clock Y, does it read the same time, an earlier time, or a later time than yours?
2) You are floating in space when you notice a flying saucer circling you. Each time it passes in front of you, you note the reading on its clock. Do you see its clock advancing faster or slower than your wristwatch? Does the space alien see your watch advancing faster or slower than his clock? Explain.
I just started learning about relativity in class, so I was just wondering if my thinking is correct so far.
1) (a) The inertial frame is your own frame, because events happen at the same location in that frame right? I think that means time would advance slower in the other frame, so clocks X and Y would advance slower.
(b) If X and Y advance slower, it would read an earlier time right?
2) The inertial frame here is the space alien's frame, because events happen at same location in that frame. Therefore you would see its clock advancing faster than yours. I'm not sure about the 2nd part of this question, wouldn't yours just seem slower to the alien?
Thanks
DWill said:
1) …
Hi DWill! :smile:
1) The concept of "because events happen at same location in that frame" is strictly correct, but it's much easier to think "an inertial observer always regards other clocks as going slower".
Your (a) and (b) are correct.
2) Again you've tried to apply "because events happen at same location in that frame" … but I've no idea why you think that applies to one frame rather than the other. :confused:
Try again, with "an inertial observer always regards other clocks as going slower". :smile:
Thanks tiny-tim for the reply, but I'm a little confused on what you said on how to figure out which is the inertial frame. How do you know in which one the clocks go slower?
An inertial observer or an inertial frame is one that has uniform velocity (ie, a fixed speed in a fixed direction), and isn't rotating. :smile:
