eep
- 225
Hi, I'm working out of Hartle's book Gravity and had a question about Ch. 5 problem 7. The problem states that a particle has constant acceleration along the x-axis, that is, the acceleration when measured in it's instantaneous rest frame is always the same constant. They want me to get the parametric equations for x and t as functions of proper time \tau, assuming at t=0 that x=0 and v=0.
I assumed that since the acceleration is constant, the three-force is also constant. I can then use
<br /> \frac{dp}{dt} = F = ma<br />
for some constant a. Since F is constant I can integrate once to get
<br /> {\gamma}m\frac{dx}{dt} = mat<br />
Or, solving for \frac{dx}{dt}
<br /> \frac{dx}{dt} = \frac{at}{\sqrt{1+a^2t^2}}<br />
Using the relationship {d\tau}^2 = dt^2 - dx^2 I can arrive at
<br /> d\tau = dt\sqrt{(\frac{1}{1+a^2t^2})}<br />
Integrating and solving for t and letting \tau = 0 when t=0 I get
<br /> t(\tau) = \frac{{\sin}h(a\tau)}{a}<br />
I can then solve for x and get
<br /> x(\tau) = \frac{{\cos}h(a\tau)}{a} - \frac{1}{a}<br />
due to the initial conditions. Did I do this right?
EDIT: I really just need to know if my first couple steps are right, as everything follows from that.
