- 9,536
- 4,781
I agree.PeterDonis said:Yes, but then your claim that the stay at home twin ages during the turnaround turns into the claim that re-synchronizing clocks can cause the stay at home twin to age. Which seems unusual, to say the least.
I think my post in another thread is relevant here:FactChecker said:I agree.
FactChecker said:In SR, when two observers are moving inertially with respect to each other, each observer thinks that the other is aging slower. In that situation, when does the stationary twin get to age faster in the eyes of the traveling twin, as you propose?
PeterDonis said:This is too extreme. The Usenet Physics FAQ I linked to has an "Equivalence Principle Analysis" page that discusses this issue.
The thing this doesn't do is provide an explanation for why naive application of the time dilation formula leads to a paradox. It is indeed a complete and very general solution to the scenario and any other similar one. But it doesn't explain the mistake, which is essentially the same one from Round the World in Eighty Days - forgetting to change your calendar when you change timing convention.PeroK said:... on the other hand, a full and comprehensive explanation of the twin paradox is:
##d\tau^2 = dt^2 - dx^2 - dy^2 - dz^2##
Yes and that shorter path the traveler takes is the space-time interval :delta s^2 = sqrt (c delta t)^ 2 - (delta x) ^2 unfortunately the symbols. no longer seem available?phinds said:It sounds like you are continuing to promote the falacious point of view that things slow down for the traveler IN HIS FRAME. That is not true. Neither his clock nor his biological processes slow down in his frame, he's just taking a different path through space-time so the NUMBER of ticks of his clock is different but not the rate at which they occur.
I think we need to be careful not to promote this very misleading point of view.
@phinds Sorry. I never meant to imply that. If something I said or terms I used implied that, then I'm sorry. I have been reading the link that @PeterDonis gave, and it is very good. It clarifies a lot that I only had a vague understanding of.morrobay said:Yes and that shorter path the traveler takes is the space-time interval :delta s^2 = sqrt (c delta t)^ 2 - (delta x) ^2 unfortunately the symbols. no longer seem available?
Edit, delta s = (same above)morrobay said:Yes and that shorter path the traveler takes is the space-time interval :delta s^2 = sqrt (c delta t)^ 2 - (delta x) ^2 unfortunately the symbols. no longer seem available?
Ibix said:The thing this doesn't do is provide an explanation for why naive application of the time dilation formula leads to a paradox. It is indeed a complete and very general solution to the scenario and any other similar one. But it doesn't explain the mistake, which is essentially the same one from Round the World in Eighty Days - forgetting to change your calendar when you change timing convention.
But for the one way example here, there is no way to avoid a synchronization assumption, because that is the sole determinant of what the start event is for the Mars clock. There is only one incident of colocation. The interval beginnings are determined solely by a synchronization decision, which can be a physical procedure, thus invariant, but it is still a choice, and effectively defines a frame.vanhees71 said:I think one saves oneself a lot of trouble, if one simply uses covariant quantities. If this is not possible, something usually is at least problematic, if not simply ill-defined or wrong, with the way a problem is stated or thought about.
In the case of the "one-way twin paradox" one can simply refer to the proper time of each twin. That's a local concept too, because it just is the time each twin reads off from his or her wristwatch. Using these proper times for the "aging" of the twins thus you get an unanimous answer to who aged more or less compared to the other. Then there's no frame dependence nor is there any paradox to be thought about left!
PeroK said:"The essence of Einstein's first insight into General Relativity was this: (a) you can derive time dilation for uniform pseudo-gravitational fields, and (b) the Principle of Equivalence then implies time dilation for gravitational fields. A stunning achievement, but irrelevant to the twin paradox. "
PeterDonis said:The use of the EP to predict time dilation in real gravitational fields is irrelevant to the twin paradox, yes. But the interpretation that a pseudo-gravitational field (which has time dilation) is present while Stella fires her thrusters, and that this pseudo-gravitational field explains how Terence ages much faster than Stella during the turnaround, is certainly not irrelevant.
PeroK said:he must get physically younger during the first phase of the second turnaround
PeroK said:Stella brakes and heads away again. Terence is back to age ##T## years (approx) in Stella's frame.
PeroK said:Stella executes the turnaround again and Terence is back to ##T + 1## years.
PeroK said:if Stella orbits a distant star at relativistic speeds, then Terence's age is going backwards and forwards during each orbit
PeterDonis said:No, he is at ##T + 2## years (plus the small increment of time he aged during the brake and head away again phase).
PeterDonis said:Stella has zero proper acceleration in this case (she's in a free fall orbit), so there is no pseudo-gravitational field, so the EP analysis does not apply.
No. Terence is always getting older. The rate will alternate between aging slowly and aging rapidly, but it will always be positive.PeroK said:Or, alternatively, if Stella orbits a distant star at relativistic speeds, then Terence's age is going backwards and forwards during each orbit.
When Stella is closing the distance he will age rapidly, when Stella is receding he will age slowly.PeroK said:That can't be right. The differential ageing relative to Terence can't depend on the number of changes of direction.
DaveC426913 said:No. Terence is always getting older. The rate will alternate between aging slowly and aging rapidly, but it will always be positive.When Stella is closing the distance he will age rapidly, when Stella is receding he will age slowly.
Agree. Though not a problem, as you put it..PeroK said:The problem is that ageing rapidly and ageing slowly don't cancel out.
They sure do. If Stella spends a great deal of time moving at relativistic velocities - in any direction - she's going to come back to a very old Terence.PeroK said:If, therefore, Stella keeps repeating the turnaround, then the years pile up for poor Terence!
Nope.PeroK said:Unless, of course, there is a part of the repeated turnaround in which Terence actually gets younger.
Agree! Post 79:PeroK said:Fundamentally, the age differential when Stella returns is determined by Stella's velocity profile over the duration. The turnaround, physically, does not do anything special to the age difference (in a short period of Stella's time). It only changes the simultaneity convention.
Although, note that Terence's very slow aging immediately begins to speed up (to normal) as soon as Stella begins her deceleration (negative acceleration) on approach to the turn around, while she still has positive velocity - and not when her velocity actually reverses.DaveC426913 said:Yes. Velocity change (specifically, sign from + to -). Not acceleration change.![]()
It will alternate between forward and backward. It will not always be positive. This is a feature of the naive construction of an accelerated frame. For any given [powered] orbital acceleration, the hyperplane of simultaneity in the tangent inertial frame of the traveler will swing back and forth on the worldline of a sufficiently distant stay at home twin.DaveC426913 said:No. Terence is always getting older. The rate will alternate between aging slowly and aging rapidly, but it will always be positive.
PeroK said:The differential ageing relative to Terence can't depend on the number of changes of direction.
We may be talking past each other here.jbriggs444 said:It will alternate between forward and backward. It will not always be positive
jbriggs444 said:It will alternate between forward and backward. It will not always be positive. This is a feature of the naive construction of an accelerated frame.
DaveC426913 said:Terence will always be getting older (his aging will always be positive).
FactChecker said:During inertial flight, the clocks and people in other, relatively moving IRFs always appear to have slow clocks and be aging slower.
