Remembering how to answer questions?
  • Thread starter Thread starter elephunk
Many engineers struggle to remember how to answer specific questions without consulting reference materials, particularly due to the increasing complexity of building codes and design regulations. The profession has shifted towards interpreting and navigating these codes rather than relying solely on memorization of formulas. While understanding fundamental principles is crucial, it's acknowledged that memorizing every equation is impractical given the breadth of knowledge required. Experience in the field helps make equations more intuitive, but the focus often leans more towards practical application than theoretical knowledge. Ultimately, engineers are encouraged to maintain access to resources and prioritize understanding over rote memorization.
elephunk
Do any engineers have problems remembering how to answer a particular question without having to look in a formula book etc?
It happens to me a lot. As a student I worry about this quite a lot. Would like someone who perhaps is in industry to give some input.
Thanks,
A good question. I'm a professional engineer (PE), in my field the building code is very important as are design codes for the various materials used in construction and we are legally required to comply with them. However, the engineers job seems to have become more one of deciphering text rather than engineering. It's not so much looking up formulas as it is navigating through all the rules and exceptions and finding relevant pieces that apply.
Maybe, long ago one might have been able to memorize the code, but the building code continues to grow in size with more and more rules to cover more and more conditions as explicitly as possible.
So I see the problem with engineers is that all they are learning to do is follow what is explicitly dictated in codes, they view there job as like following a cookbook. To some extent that is exactly what it is, but it gets increasingly difficult for them to take advantage of the best exception of all which is: "or using rational analysis"
I'm not sure if that is along the same lines as your question but hopefully it makes sense.
(rereading your question I would say the most important thing is to understand the formula, you can usually keep as many books as you need near your desk, or on hard drive)
I think as long as you remember the fundamentals, the general principles, and where to look up specific information you will be fine. Most of us cannot realistically expect to be able to remember every formula we have ever seen.
Formula sheets are there for a reason. One could try and memorize this information but for what purpose?
When you gain experience in a field, the equations will become like second nature to you because you work with them on a regular basis. During undergrad however, you are bombarded with many different equations from many different subject areas that of course you won't have them memorized.
Alternatively, many engineering spend very little time working on the theoretical implementation of things and more time on the practical implementation of things (like building a building to code as mentioned by sardonicus). It really depends what type of job you are doing if you'll end up using many equations.
Be Blonde!
Here are some bolndes jokes or stuff.
Blonde’s Story
A blonde is sitting at home one day when she decides she’s sick of hearing blonde jokes. She decides to dye her hair brown, and, to see if it works in making her more intelligent, goes to a farm where she approaches the farmer with the challenge, “If I can guess how many sheep you have, can I take one home?” The farmer chuckles to himself, before replying, “Sure, why not?” The blonde pulls out a calculator and does a bunch of hugely complicated equations and comes up with a number. She says to the farmer, “There are 314 sheep out there.” The farmer is astonished. “You’re right!” he says. “Go take your pick”. The blonde takes a few minutes to pick a sheep, waves to the farmer, and leaves. She’s sitting at home the next day when she hears a knock on her front door. She opens it and finds the farmer standing there holding his hat. He says to her, “If I can guess your real hair colour, can I have my dog back?”
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
