Renewal Process: laplace transform approach
SantyClause
Use the Laplace transform approach to find the renewal function for a renewal process with interrenewal p.d.f. as follows:
g(x) = (c^2)xe^(-cx) , x > 0
M*(s) = G*(s)/(1-G*(s)) where M*(s) and G*(s) denote laplace transforms
I have that G*(s) = -c/(c+s)^2 - 1/(c+s) and when I plug that into the above equation I get something that isn't easily inverted :(
It should be noted taht I haven't used laplace transforms in YEARS and they were always very weird to me.
You need to be more careful: M* and G* are Laplace transforms or WHAT? If ##\tilde{f}(s)## is the LT of f(x), then since f is the density of a 2-Erlang random variable (= a sum of two iid exponentials), we have that its LT is the product of the exponential LTs:
\tilde{f}(s) = \frac{c^2}{(s+c)^2}. I don't know how you got your G*(s). If you thought you wanted the LT ##\tilde{F}(s)## of F(x) = cdf of f(x), you should have gotten
\tilde{F}(s) = \frac{1}{s} \tilde{f}(s) = \frac{c^2}{s(s+c)^2} = <br /> \frac{1}{s} - \frac{c}{(s+c)^2} - \frac{1}{c+s}.
Anyway, the renewal density m(t) has LT ##\tilde{m}(s)## given by
\tilde{m}(s) = \frac{\tilde{f}(s)}{1-\tilde{f}(s)},and the renewal function
##M(t) = \int_0^t m(\tau) \, d\tau## has LT \tilde{M}(s) = \frac{1}{s} \tilde{m}(s).
Ok I think I understand now. Of course the two things should have been off only by 1/s.
But for the following formula
\tilde{m}(s) = \frac{\tilde{f}(s)}{1-\tilde{f}(s)},[/tex]
we are supposed to use the density rather than the cdf?
I'll let you figure out the reason, but I wrote exactly what I said and meant.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
