Represent the concept of Time best?
In summary,The flash animations "A" and "B" represent the concept of time best. "B" is more like what Fotini Markopoulos talks about and she is prettier than you or me, so we have to consider it :wink:. There was a profile of her and her 'quantum causal histories' research in the SciAm a couple of months ago and had a photo of her. Maybe kikuchiyo is on to something.
Which is a better graphical representation of time?
  • [URL=http://homepage.mac.com/aglaser/time.swf]A.[/URL]
    Votes: 6 42.9%
  • [URL=http://homepage.mac.com/aglaser/time2.swf]B.[/URL]
    Votes: 8 57.1%
  • Total voters
kikuchiyo
Which of these flash animations do you think represent the concept of Time best? Why?
A. http://homepage.mac.com/aglaser/time.swf
B. http://homepage.mac.com/aglaser/time2.swf
I voted for animation "A". It seems like the traditional represention of Time. How events happen on a timeline in orderly fashion, one after the other in perfect concession. kikuchiyo, could you explain your idea of representation "B"?
Greg,
version "B" is more like what Fotini Markopoulos talks about
there was a profile of her and her 'quantum causal histories' research in
maybe kikuchiyo is on to something
My original thoughts behind example B. was, what if time overlapped allowing a bit of the past to show through if you could look at it flat. Instead of the traditional linear explanation (A.) Being a graphic designer I'm forced to think about these things in a visual manner.
in convential quantum mechanics a particle can get from point X to point Y without having a continuous trajectory
the continuous trajectory is a classical idea (very good as long as you don't push it past the limits of applicability)
but in quantum mechanics there are only observations along the way and probabilities of getting from here to there---no smooth trajectory
the timeline or time axis in a naive spacetime diagram is a
trajectory idea
and in what I've seen of quantum models of the world
there is this kind of hopping from one spatial configuration to
another, with a history of causality that let's a spacelike slice at the bottom of the pile influence those that cover it, but there is
no one preferred trajectory
this is just one reading of your animation "B"
but it works for me at least---agrees with what I see
people struggling to say about time when they are
trying to quantize general relativity
let's think of as many interpretations as we can, there is often more than one interpretation of a graphic
Why does kikuchiyo's intial post say it was last edited by Greg Bernhardt on 08-27-2003 at 02:49 PM?
kikuchiyo is a work friend of mine and his orginal format and wording of his question was confusing, so he let me help him out to make it more clear. Now back on topic! :smile:
Each example is good for different purposes. The first one more clearly represents motion rather than time per se, while the second one represents change. A three dimensional combination of the two would be more complete imo, but which is better just depends upon the context in which you use it.
I follow Wuliheron in that there is the human defenition of time and then the physics defenitions of time, which is better depends on what entanglement you find yourself in and which solves it better.
I like the patchwork idea in that history affects history, not a continuous static line of events as the other suggests.
Is A supposed to be repeating? Is B building "up", in other words, are those pieces building on top of each other or are they replacing each other?
The graphics repeat but only to keep the file size down. You should consider only one cycle of the animation.
Animation B. builds on top of the older tiles. So they overlap not replace.
I think I have to go with "A". You see, "B" implies a second dimension of time, and I've never been comfortable with such an idea.
nice thing about a graphic (animated or not) is that one sees in it what one sees in it
I don't understand how you see 2 dimensions of time but that is all right. I see only one----the leaves are piling "up"
mathematical idea of partial ordering
of spacelike slices if you want
The reason I see two dimensions of time, is because these "spacelike slices" are not falling directly on top of each other. That is actually the point of that graphic (which differentiates it from option A): it doesn't require that all events fall orderly, in a series.
IOW, since these "slices" are falling in a way that allows one to see th previous "slice", they are not falling in a "straight line". And if they are not falling in a "straight line" then you imply another "direction of movement" which is what "dimension" means.
I had the same problem with the idea of "pretzeling time". In order to "bend" time so that you can go back to the past, you have to move in a different dimension of time (an "upward" one, in my mental picture).
i have no physics real background to suggest this but ideas i hear, but i agree with neither :)
i tihnk time is a straight track which you can turn around on and go back. like stephen hawking suggested in a brief history of time (?). Being an optomist i want to believe that's possible, and i tihnk as long as there is a limit to something (super-strings being the current favorite) then there has to be a defining thing (the smallest thing). When we learn more about the strings (i know, hundreds, perhaps thousands of years in the future) then we will learn every answer we want!
after all the laws of physics have to be held somewhere, they can't just BE!
1. What is the concept of time?
The concept of time refers to the measurement of the duration of events and the sequence in which they occur. It is a fundamental aspect of our existence and is often described as the fourth dimension.
2. How is time represented in science?
In science, time is represented using a linear scale, usually measured in seconds. It is a continuous and absolute quantity that can be measured and compared with other quantities, such as distance and mass.
3. What are some common ways of representing time?
There are several common ways of representing time, including clocks, calendars, and timelines. Clocks use hands or digital displays to show the current time, calendars display dates and months, and timelines show the chronological order of events.
4. How does the concept of time differ between cultures?
The concept of time can vary between cultures, with some cultures valuing punctuality and efficiency, while others have a more relaxed attitude towards time. Additionally, different cultures may have different ways of measuring time, such as using lunar cycles or the positions of the sun and stars.
5. Can time travel be represented in science?
While time travel is a popular concept in science fiction, it is not currently possible or scientifically proven. The laws of physics, specifically the theory of relativity, suggest that time travel into the past is not possible. However, some scientists believe that traveling into the future may be theoretically possible through certain processes, such as traveling at near light speed.
  • Other Physics Topics
  • General Math
