Reps of groups and reps of algebras
  • Thread starter metroplex021
  • Tags
    Groups
In summary, the conversation discusses basic questions about fundamental representations, specifically in the context of locally isomorphic semi-simple Lie groups and their relationship to representations of the corresponding Lie algebra. It is mentioned that every representation of a semi-simple Lie algebra can exponentiate to give a representation of the associated semi-simple Lie group. However, this is not always the case for non-simply-connected groups, and the fundamental representation(s) of these groups may not be obtainable by exponentiating the fundamental representation(s) of the algebra. It is also asked whether different non-simply-connected groups will have different fundamental representations, and references are provided for further information.
metroplex021
151
Hi folks - I have a couple of basic questions about fundamental
representations.
First of all, does every group have a set of fundamental
representations?
Secondly, I know that in the case of the (compact?) semi-simple groups, any other
representation of the group can be constructed by taking tensor
products of its L fundamental representations, where L is the group's
rank. Is this the case for all groups, or just the semi-simple ones?
Any help would be really appreciated. Thanks!
Mathematics news on Phys.org
I've got what might be a couple of very basic questions on the fundamental representations of locally isomorphic semi-simple Lie groups and their relationship to representations of the corresponding Lie algebra. I know (from reading Cornwell, 'Group Theory in Physics') that every representation of a semi-simple Lie algebra exponentiates to give a representation of the unique, simply connected semi-simple Lie group associated with that algebra. (So for example, every representation of the algebra su(2) exponentiates to give a representation of the group SU(2).) I also know that, at least in some cases (such as with the group SO(3), which also has su(2) as its algebra), it is not the case that every representation of the algebra exponentiates to give a representation of a given non-simply-connected group associated with that algebra. The first non-trivial representation of SO(3), for example, is not obtainable by exponentiating the fundamental (2-dimensional) representation of su(2) (with highest weight 1/2), but is rather obtained by exponentiating the 3-dimensional representation of the algebra (with highest weight 1).
So I have two questions on the same theme as the above.
1. Is it always the case that the fundamental representation(s) of the various non-simply-connected semi-simple Lie groups associated with a given semi-simple Lie algebra are not obtainable by exponentiating the fundamental representation(s) of the algebra?
2. Do the fundamental representation(s) of each of the different non-simply-connected groups correspond to different representations of the algebra? (That is, will two groups that are locally but not globally isomorphic always have different fundamental representations?)
Any knowledge anyone can bring to bear on this would be really appreciated. (I'm pretty sure the second in particular is trivial, but I'm not sure as at the level I'm at in physics we pretty much always work with representations of the algebras and I'm not familiar with how they relate to the representations of the groups.) Thanks a lot.
representations.
representations?
No, simply because fundamental representations are only defined for semi-simple Lie groups.
See above. Any representation is a direct sum of irreducible representations, which fundamental representations are.
The general connection is given by
\begin{align}
\operatorname{Ad}(\varphi(g)) \circ D\varphi = D\varphi \circ \operatorname{Ad}(g)
\end{align}
for group homomorphisms. A group representation is a special group homomorphism ##\varphi\, : \,G \longrightarrow GL(V)##
Maybe this could help:
https://www.physicsforums.com/insights/lie-algebras-a-walkthrough-the-representations/
Otherwise I'd like to refer to the references at the end of the article.
1. What is the difference between reps of groups and reps of algebras?
Reps of groups and reps of algebras refer to two different mathematical concepts. Reps of groups involve studying the different ways a group can be represented using matrices, while reps of algebras involve studying the different ways an algebra can be represented using linear transformations.
2. How are reps of groups and reps of algebras used in physics?
In physics, reps of groups and reps of algebras are used to describe the symmetries and transformations of physical systems. They are particularly important in quantum mechanics, where they are used to describe the behavior of particles and their interactions.
3. What is the relationship between reps of groups and reps of algebras?
Reps of groups and reps of algebras are closely related, as they both involve studying the different ways a mathematical object can be represented. In fact, reps of algebras can be thought of as a generalization of reps of groups, as algebras are more general mathematical structures than groups.
4. What are some examples of reps of groups and reps of algebras?
An example of a reps of groups is the representation of rotations in three-dimensional space using matrices. An example of a reps of algebras is the representation of the Lie algebra, which is used to study the symmetries of continuous systems.
5. How do reps of groups and reps of algebras relate to other areas of mathematics?
Reps of groups and reps of algebras are important concepts in many areas of mathematics, such as abstract algebra, differential geometry, and topology. They are also closely related to the study of Lie groups and Lie algebras, which have applications in many areas of mathematics and physics.
  • Linear and Abstract Algebra
  • Differential Geometry
  • Topology and Analysis
  • General Math
