JosephK
- 38
- 2
An oceanographer is studying how the ion concentration in seawater depends on depth. She makes a measurement by lowering into the water a pair of concentric metallic cylinders at the end of a cable and taking data to determine the resistance between these electrodes as a function of depth. The water between the two cylinders forms a cylindrical shell of inner radius r_a, outer radius r_b, and length L much larger than r_b,. The scientist applies a potential difference ΔV between the inner and outer surfaces, producing an outward radial current I. Let ρ represent the resistivity of the water.
ΔV = El
R = ρ l / a
The potential difference is maintained across concentric metallic cylinders. We know for a wire of length l with a potential difference maintained across is ΔV = El. In this case, an outward radial current I is produced. In other words, current flows inbetween the cylinders. Thus, charges flow from r_a to r_b. Hence, length l is r_a - r_b. Finally, ΔV = E(r_a - r_b).
In the equation R = ρ l / A, A is cross-sectional area of the conductor (saltwater is good conductor) which is pi(b^2-a^2).
So, I learn that current density equation is only valid if the cross sectional area A is perpendicular to the current density. So, an area perpendicular to the current are cylinders.
So A = 2 pi r L, for some radius r.
Then, I need integrate from r_a to r_b with respect to r.
So, I write
dA = 2pi r L dr ?
The reasoning for length is still valid.
So, ∫dR = ∫^{r_b}_{r_a}ρ ( (r_a - r_b) / (2pi r L dr)
R = \frac{ρ(r_a - r_b) }{2\pi L }∫^{r_b}_{r_a} \frac{1}{ r dr}
R = \frac{ρ(r_a - r_b) }{2\pi L } ln\frac{r_a}{ r_b}.
Please help
