Potential Drop Across Resistor - Explained
  • Thread starter jaredvert
  • Tags
    Resistors
In summary, when someone mentions a "potential drop" across a resistor, they are referring to the difference in voltage between two points in a circuit. This does not necessarily mean that the actual voltage has decreased, but rather that there is a difference in voltage between two points. This can be seen in examples such as a single battery and resistor in parallel, where the potential drop is equal to the voltage of the battery. In series circuits, the potential drop is divided among the resistors, but the current remains the same.
jaredvert
61
When one says there is a "potential drop" across the resistor, they do not mean the actual voltage has gone down right? They just mean the current has? But then I question that because since the current goes down then the voltage has to as well? I am fuzzy on this subject, can you explain? Why is there a potential drop? Just because the current goes down?
Voltage "goes down"
Yes, they do.
For example, consider a single battery, and a single resistor in parallel. The voltage at the + side of the battery is +V, and the voltage at the - side of the battery is zero volts. The difference (potential drop) would be V.
For two equal value resistors in series with the same battery half of the voltage drops across each resistor. For unequal resistances in series, you have a voltage divider. The current through both is the same and V = IR, so what do you think will happen?
Related to Potential Drop Across Resistor - Explained
1. What is potential drop across a resistor?
Potential drop, also known as voltage drop, is the decrease in electric potential across a resistor as current flows through it. It is measured in volts (V) and is directly proportional to the resistance of the resistor.
2. How is potential drop across a resistor calculated?
The potential drop across a resistor can be calculated using Ohm's Law, which states that voltage (V) is equal to current (I) multiplied by resistance (R). This can be written as V = IR. Therefore, the potential drop is directly proportional to the current flowing through the resistor and inversely proportional to the resistance of the resistor.
3. What factors affect the potential drop across a resistor?
The potential drop across a resistor is affected by the current flowing through it and the resistance of the resistor itself. The potential drop will increase as the current increases, and decrease as the resistance increases.
4. Why is the potential drop across a resistor important?
The potential drop across a resistor is important because it determines the amount of energy that is dissipated as heat. This is useful in controlling the flow of electricity and protecting other components in a circuit from damage. Additionally, potential drop is a key concept in understanding and analyzing circuits.
5. How does the potential drop across a resistor impact the overall circuit?
The potential drop across a resistor impacts the overall circuit by reducing the voltage available to other components. This is due to the fact that the voltage is "dropped" across the resistor and is not available for use in other parts of the circuit. This can affect the performance of the circuit and must be taken into consideration when designing and analyzing circuits.
  • Other Physics Topics
