Resultant amplitude of two interfering waves
To calculate the resultant amplitude of two interfering waves at a given point, two equations are commonly referenced: A_r = √(A_1² + A_2² + 2 A_1 A_2 cos(φ)) and 2A cos(δ/2) sin(kx - ωt + δ/2). The first equation focuses solely on amplitude, while the second encompasses the entire wavefunction. In the second equation, the amplitude is represented as 2A cos(δ/2), assuming A1 and A2 are equal. The variables φ and δ in the two equations are equivalent, differing only in nomenclature. Understanding these relationships clarifies how the equations are connected.
Maxo
How do you calculate the resultant amplitude of two interfering waves, at any given point?
I found two different equations:
A_r = \sqrt{A_1^2 + A_2^2 + 2 A_1 A_2 \cos{\varphi}}
but also
2A cos(\delta/2)sin(kx-\omega t+\delta/2)
How are these two equations related?
To compare the two equations you must understand that the 1st equation shows just the amplitude while the 2nd equation shows the whole wavefunction. The amplitude in the 2nd equation is just 2Acos(δ/2). Also the second equation assumes A1 and A2 are identical A1=A2=A. Finally, the ø of the first equation and the δ of the second are the same thing under different names. May be now you can find how they are related?
Thanks.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
