Resultant Force on -2x10^-6 C Point Charge Near 3 & -4x10^-6 C
The discussion revolves around determining the resultant force acting on a point charge of -2 x 10^-6 C located at the origin, influenced by two other point charges, 3 x 10^-6 C and -4 x 10^-6 C, positioned at specified distances along the coordinate axes. The problem involves applying Coulomb's law to calculate the forces exerted by these charges and understanding their vector components.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of Coulomb's law and the calculation of force vectors. There are attempts to clarify the direction and magnitude of the resultant force, with some questioning the signs and components of the forces involved. Others express confusion about the methods used for vector addition and the interpretation of the problem statement.
The discussion is active, with participants sharing their calculations and reasoning. Some guidance has been offered regarding the vector components and the process of summing forces, although there is still uncertainty and differing interpretations regarding the correct approach and understanding of the problem.
Participants are grappling with the implications of the signs of the charges and the resultant vector's direction. There is also mention of potential misunderstandings regarding the relationship between the resultant force and the sum of the individual force vectors.
wheybags
Determine the resultant force acting on a point charge of -2 x 10 ^-6 C situated at the origin of a rectangular coordinate system in the vicinity of point charges 3x10^-6 C and -4x10^-6 C at distances 0.12 m along the positive x-axis and 0.08m along the half-line x=y where x,y>0 respectively.
Coulomb's law
I used Coulomb's law twice, taking first the first and second points, the the first and third points, and got -3.75 and 11.25 respectively.
However, the answer is supposedly 14.15 < 34.20°, which I am nowhere near to, and do not even understand.
Help greatly appreciated.
Coulomb's law
This is the correct magnitude of the two force vectors (what are the units?). What do you get for the magnitude and direction of the vector sum of these two force vectors?
That answer does not appear to be correct. You can easily tell the general direction of the resultant force - it has to be below the line x=y where x,y<0
AM
I don't know how to do that... Sorry, I'm pretty awful at this.
Could anyone perhaps do out a step-by-step solution? I could use it as an example for other questions.
One thing i like to do when it comes down to charge and vectors is to first find the force Qqk/r then later multiply it by its respective i j k multipliers
Eg. F(cos a i + sin a J).
Then i do this for both charges and sum up the respective vectors.
Ok. The force from the charge that is .12 m away on the x-axis is +3.75 N attractive so it is in the direction of the +x axis. Draw an arrow from the origin with a length of 3.75 N pointing in the positive x direction. We write that vector as: (3.75,0)
The force that is .08 m away on the line x = y, which is 45 degrees above the x axis, is -11.25 N, repulsive, so it is away from that charge ie. in a direction of 180+45 = 225 degrees. The x component of that force is 11.25cos 225 = -7.95 N. The y component is the same: 11.25 sin 225 = -7.95 N. We write that vector as: (-7.95, -7.95) .
To find the resultant vector, add them: (3.75,0) + (-7.95, -7.95). To do this, add the x components to find the x component of the sum of those two vectors: x component = 3.75-7.95 = -4.20 N. The y component of the resultant is -7.95 + 0 = -7.95 N.
So the result is a vector (-4.2,-7.95).
Can you work out the length and the direction of that vector?
AM
I don't understand why you reversed the sign of the two charges.
Also:
Why would the x and y component be 11.25 cos 225?
Could one not do it like this?
[PLAIN]http://img146.imageshack.us/img146/7062/grapheg.png
sin 45 = o/h = y/0.8 = 1/sqrt(2)
=> y = 0.8/sqrt(2) = 0.565
But obviously this is a different answer.
Also:
The question was to determine the resultant force acting on the point, not the sum of the two other vectors, or is that the same thing?
Since the charge at origin is negative, the force by the charge lying on x-axis will be attractive (and since it lies on positive side of x-axis, the direction of force on charge at origin is positive), and repulsive by the charge lying on x=y (by similar argument as above, force on charge at origin in the negative x,y direction).
Not sure what you are trying to say here.
Yes, they are indeed the same thing.
I'm asking why the method I proposed is not a valid solution, and why the the one that AM posted is.
You are taking the y component of the displacement for some reason that you do not explain.
You have to take the x and y components of the FORCE vector not the displacement vector. The length of the FORCE vector is inversely proportional to the square of the length of the displacement vector.
We represent each force by a vector. The vector's length is proportional to the force and points in the direction of the force. To add forces, we add the force vectors using the vector addition method (put two force vectors tail to head and then measure the length and direction of the vector from the tail of the first to the head of the second). That is all I have done.
AM
14K
  • · Replies 20 ·
