I Retro/prograde flyby galaxies and their bar formation
  • I
  • Thread starter Thread starter milkism
During a 1:1 prograde passage, bar formations occur in both galaxies due to prolonged gravitational interactions, while in a retrograde passage, these formations are absent. The gravitational forces in a retrograde passage are equal in magnitude but opposite in direction, leading to a net effect that does not promote bar formation. The discussion highlights that the duration of gravitational influence is crucial; stars in a prograde flyby experience closer proximity for longer periods, enhancing structural perturbations. The significance of a reference frame where one galaxy is relatively stationary is also questioned, suggesting it may impact the understanding of interactions. Overall, the complexities of galaxy dynamics necessitate extensive simulations to fully grasp the underlying physics.
milkism
TL;DR Summary
In fast flyby encounters, typically involving a smaller or equal in mass galaxy (secondary) passing by a relatively stationary galaxy (primary), a bar formation can occur in either the secondary galaxy or both galaxies. This depends on their masses and their relative motions (whether prograde or retrograde).
https://iopscience.iop.org/article/10.1088/2041-8205/790/2/L33/pdf
In section 3, it states that during a 1:1 prograde passage, bar formations are visible in both galaxies, whereas in the retrograde version, there are no bar formations in either galaxy. I would like to understand the physics behind this.
My initial thought is as follows:
During a 1:1 retrograde passage, the gravitational interactions of both galaxies are equal in magnitude, but their signs differ. Therefore, if we sum up all the gravitational forces, the net effect would be zero.
Is this partially correct (of course, aside from gravitational forces, there are other factors too) or am I completely wrong?
Astronomy news on Phys.org
Do you think there is any significance of a reference frame in which one of the galaxies is 'relatively stationary'?
If the physics was easy to understand we wouldn't need to spend thousands of hours of CPU time performing simulations.
Yes, according to Newton's third law. How is this different in a prograde passage?
I don't think so. Galaxy flybys may cause perturbations in galaxy structure due to the gravitational attraction of individual stars towards the "other" galaxy. In a prograde flyby individual stars are closer to the other galaxy for much longer than in a retrograde flyby (similar to the difference between a car overtaking you and a car passing in the opposite direction) so this attraction has a much greater effect.
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
