Review in calc I to prepare for calc II
  • Thread starter Thread starter ranger
    Prepare Review
ranger
I'm doing a review in calc I to prepare for calc II. I'm now applications of derivatives (optimization). Okay so when I have the function I need to optimize, I need to take the derivative and find the critical point of the first derivative. But sometimes there's more than one critical point. Is there any sort of test that I can do to find which critical point I should use.
--thank you.
Why not a first derivative test? I assume you have done one before. If the derivative is negative until the critical point, then positive after the critical point then you have a maximum. The other way around for a minimum. Essentially limits with derivatives.
Ah the first derivative test. Thanks for the input.
Other way around, if the derivative is negative to the critical point and the positive after the value at that point is a minimum, because the function decreases to that point and then increases.
You could also get the second derivative and evaluate it in the critical points (where the first derivative is zero). If the second derivative is negative you have a maximum, if it's positive you have a minimim and if it's zero you have (what i directly translate from dutch, because I don't know what it's called in english) a bending point, as you would have in the function y=x^3. If calculating the second derivative isn't too much work, I generally use this method to establish the nature of a critical point.
