Calculating Reynold's Number for a Passenger Jet Cruise
The discussion focuses on calculating the Reynolds number for a passenger jet cruising at 525 mph at an altitude of 39,000 ft. The relevant parameters include a wing chord of 3 m, a local density of 6.14 x 10-4 sl/ft3, and a dynamic viscosity of 2.97 x 10-7 lbf-s/ft2. The formula used is Re = (ρvL)/μ, where ρ is density, v is velocity, L is length, and μ is dynamic viscosity. After converting units to maintain dimensional homogeneity, the calculated Reynolds number is approximately 15,667,833.16, which is consistent with expected values for high-speed airflow over a jet wing.
  • Understanding of fluid dynamics principles, specifically Reynolds number.
  • Familiarity with unit conversions between imperial and metric systems.
  • Knowledge of dynamic viscosity and its units (lbf-s/ft2).
  • Basic proficiency in using mathematical equations for physical calculations.
  • Research the implications of Reynolds number in aerodynamics.
  • Learn about unit conversion techniques between imperial and metric systems.
  • Explore the significance of dynamic viscosity in fluid mechanics.
  • Study the effects of altitude on air density and viscosity for aviation applications.
Aerospace engineers, physics students, and anyone involved in fluid dynamics or aerodynamics calculations will benefit from this discussion.
Spartanlol
A passenger jet cruises at 525 mph and an altitude of 39,000 ft. The wing chord is 3 m. If the local density is 6.14 x 10-4sl/ft3 and the dynamic viscosity is 2.97 x 10-7lbf-s/ft2, what is the cruise Re number based on the chord? Make sure your units are consistent in your calculations!
2. Equation for Re, which I believe is Re=(pvL)/u where p=density, v=velocity, L=length, u=dynamic viscosity. We haven't been taught the equation, supposed to find it online, and I believe this is it.
3. My issue is I am confused as to what units I should keep everything in and also I have no idea what lb-s/ft2 is.
Why don't you look up (or write down) the units of viscosity that you are familiar with, and maybe you can work backwards from that (swapping one at a time a metric-type unit into its imperial version) to allow you to figure out these imperial ones.
lbf is probably pounds or pounds force, but I'm guessing.
UPDATE
Just tried to solve it myself and I think it worked. I turned 6.14x10^-4 slug/ft^3 to .3164 kg/m^3, 525mph to 234.696 m/s, and 2.97x10^-7 lb-s/ft^2 to 1.422x10^-5 N-s/m^2
I think those were the correct unit required to keep this dimensionally homogeneous since Re number is unitless. I am pretty sure my conversions are correct, if anyone notices one is off please tell me. After typing these into the equation (I didn't round on my calculator for these conversions like I showed here) I ended up with Re=15667833.16
I am not sure if that is it or if it's even a reasonable number (never used Reynold's equation before) so please tell me if this looks strange.
25K
