What is the Direction of Magnetic Field Lines?
  • Context: High School
  • Thread starter Thread starter ppppparker
    hand Right hand rule
The discussion clarifies the concept of magnetic field lines and their direction in relation to current-carrying wires. It emphasizes that magnetic field lines curve around a straight wire, and their direction can be described as either "into the page" or "out of the page," depending on the perspective. The direction of the magnetic field determines the motion of a moving charge, which can circulate clockwise or counterclockwise. Understanding these concepts requires a clear grasp of the right-hand rule (RHR) and the ability to visualize magnetic field lines through diagrams.
  • Understanding of magnetic fields and their properties
  • Familiarity with the right-hand rule (RHR) for determining magnetic field direction
  • Basic knowledge of electric current and its effect on magnetic fields
  • Ability to interpret diagrams of magnetic field lines
  • Study the right-hand rule (RHR) in detail to understand its application in magnetic fields
  • Learn how to draw and interpret magnetic field line diagrams for various configurations
  • Explore the relationship between magnetic fields and forces on moving charges
  • Investigate the behavior of magnetic fields around different shapes of conductors
Students of physics, educators teaching electromagnetism, and anyone seeking to deepen their understanding of magnetic fields and their applications in real-world scenarios.
ppppparker
This is completely confusing me, please help. The word that is giving me problems is "direction".
The text talks about the "direction of the magnetic field lines" . As I understand it, the fied lines curve around a straight wire. So you can only have two directions, clockwise or anticlockwise. But are they saying that clockwise or anticlockwise is a a direction??
Im also confused when field lines are described as "into the page" or "out of the page". If the mag field lines wrap around the wire, then wouldn't that mean the field lines are going into the page on one end of wire and out of page on the other end (if you looking top down onto a wire)? So it should be both into and out of paper right?
there's also this practice question in the text (that I will separete from this post and repost in homework questions, if necessary?) and it specifically asks this:
"A moving negative charge placed in an external magnetic field circulates counterclockwise in the plane of the paper. In which direction is the magnetic field pointing?"
-Is that a typo? Shouldnt it be asking about the direction of the magnetic force? (because the field lines go either clockw or anticlockw)? Or is this just more of me not understanding fields?
Thanks for any help. I really want to understand RHR...Its making me crazy.
Imagine the centre of mass of an object is located at some point in space. Then you say it is rotating about the centre of mass point say at some angular frequency, but you need to specify an axis about which it is rotating. It is because you have to choose an orientation in space for this axis (a line in space) that rotational problems require direction (in 3d, not in 2d though if you think about it). Once you have chosen your line axis for rotation, you still need to specify whether it is rotating around the line clockwise or anti-clockwise. This reflects the fact that if you were moving along the axis line, you could move upwards or downwards. I'm not saying that when things rotate they are moving up or down the axis of rotation, but just that once you have specified an axis for rotation, spinning one way represents upwards, and spinning the other way represents downwards. The whole point though about the need for "direction" and vectors in rotational problems boils down to the fact that you need to pick out an an axis for the rotation, which points along a direction in space. Does this help?
No typo. The direction of the magnetic field (whether it's pointing into the page or out of the page) will determine whether the charge goes clockwise or anti-clockwise. The direction of the magnetic force for either case will always point towards the centre of the circle.
"The text talks about the "direction of the magnetic field lines" . As I understand it, the fied lines curve around a straight wire. So you can only have two directions, clockwise or anticlockwise. But are they saying that clockwise or anticlockwise is a a direction??"
There is ambiguity in your understanding ad in your statements. I quoted your first statement above. It is true that the field lines curve around a straight wire, but that does not specify which way they curve. Your textbook states it very clearly, and you should read that before you proceed.
"If the mag field lines wrap around the wire, then wouldn't that mean the field lines are going into the page on one end of wire and out of page on the other end (if you looking top down onto a wire)? So it should be both into and out of paper right?"
The above statement is not clear at all. If, as you yourself say, the field lines are curving "around" the wire, where do the ends of the wire come into the picture? You should draw a diagram, so that the statements are clear to you as well as to others.
I really suggest you draw diagrams. Questions about which way a charge moves in a magnetic field should follow only after you clearly know how to figure out the direction of the magnetic field due to a current.
The magnetic field lines form a closed loop around any shape of conducting loop so they are pointing all over the place. The direction that you use is the direction of the lines at the point of interest. CLockwise or Anticlockwise are just general descriptions. These ideal circular patterns will only be found for a perfectly straight wire, very long and far away from anything else.
  • · Replies 22 ·
  • · Replies 32 ·
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 42 ·
