Rigid body orientation using Euler angles confusion
The discussion centers on the relationship between angles α and β in relation to Euler angles in a rigid body orientation problem using the ZXZ convention. The correct relationships are established as α=θ+0.5π and β=ϕ. The confusion arises from the initial assumptions about the rod's orientation and the effects of rotations about the Z-axis. Ultimately, it was confirmed that the lecturer made an error in the solution provided, leading to a misunderstanding of the problem.
  • Understanding of Euler angles, specifically ZXZ convention
  • Knowledge of rigid body dynamics and orientation
  • Familiarity with trigonometric relationships in 3D space
  • Basic principles of rotational transformations
  • Study the implications of the ZXZ Euler angles convention in rigid body dynamics
  • Learn about the mathematical derivation of Euler angles and their applications
  • Explore common mistakes in interpreting rigid body orientation problems
  • Investigate the effects of different rotation sequences on body orientation
Students and professionals in mechanical engineering, robotics, and physics who are dealing with rigid body dynamics and orientation problems.
Tar
Hello,
I'm given the following exercise:
"A rod with neglected thickness exists. What is the relation between the α,β angles to Euler angles of orientation?
α is defined as the angle between the rod and its projection on the XY plane.
β is defined as the angle between the X-axis and the rod's projection on the XY plane.
(Note: We are using ZXZ Euler angles convention, having the following order of angles: ϕ,θ,ψ.)"
The answer is: α=θ+0.5π, β=ϕ
I don't understand why.
As far as I know, usually the body points in the e3 direction in the body frame. Initially the body frame points towards the original Z direction, after rotation of ϕ around the Z axis, and then rotation of θ around the x′ axis, we will receive the following:
Note that the new z′ axis doesn't point to where it should be (according to the answer) and ϕ doesn't represent the angle between z' axis' projection on the XY plane and X-axis.
What am I missing?
Thank you.
This is not clear from the statement of the problem, but let's assume that it is true. If e3 is the Z direction, a rotation about that axis by any angle will not change the orientation of the rod, but will change the orientation of the x and y axes to x' and y'. Now to get the rod below the x'y' plane, you will need angle θ greater than π/2. The solution says that's not the case. So either your assumption about the original orientation of the rod is incorrect or the solution is incorrect.
On edit: Welcome to PF.
:welcome:
:welcome:
You're right. the lecturer have verified again (for the 3rd time) and there's a mistake that he hadn't noticed on his first verification.
I think this thread should be deleted as it doesn't help anyone,
Thanks for your help.
  • · Replies 18 ·
