Rigorous definition of continuity on an open vs closed interval
kahwawashay1
Let I be an open interval and f : I → ℝ is a function. How do you define "f is continuous on I" ?
would the following be sufficient? :
f is continuous on the open interval I=(a,b) if \stackrel{lim}{x\rightarrow}c \frac{f(x)-f(c)}{x-c} exists \forall c\in (a, b)
is this correct?
Also, what about the case of a closed interval I? In that case, can you just add to the above statement that:
\stackrel{lim}{x\rightarrow}a^{+} f(x) = f(a)
and
\stackrel{lim}{x\rightarrow}b^{-} f(x) = f(b)
The definition you gave is for differentiability on an open interval. The definition for continuity is with delta and epsilon. The [ itex ] for lim looks like \displaystyle{\lim_{x\rightarrow a}}.
But differentiability implies continuity?
Anyway, then would this be right:
f is continuous on the open interval I=(a,b) if |\frac{f(x)-f(c)}{x-c} - f'(c)|< ε when |x-c|<δ \forall c\in (a, b) and what about my use of the right and left hand limits for the case of a closed interval [a,b]? would that be correct?
dextercioby said:
No, f is differentiable on the open interval I=(a,b) if |\frac{f(x)-f(c)}{x-c} - f'(c)|< ε when |x-c|<δ \forall c\in (a, b) [...]
ohhhh nvm. it can be continuous on (a,b) but not differentiable, like the abs value of x.
Ok then it would just be:
f is continuous on (a,b) if \displaystyle{\lim_{x\rightarrow c}} f(x) = f(c) \forall c\in (a, b)
right?
Yes, but for that limit to make sense, you have to use the topology, that is compare values of f(x_1) and f(x_2) when x_1 and x_2 get arbitrarily close to each other. That's what the epsilon-delta definition does.
we didnt learn about topology yet so idk what is f(x_1) and the like...
