Engineering RL circuits and unit step functions
The discussion focuses on understanding the behavior of current in an RL circuit with unit step functions. Initially, the current is zero, and for 0 < t < 1, the voltage is also zero, leading to an exponential rise in current that levels off at 1/6 A. The confusion arises regarding the role of a 3Ω resistor, which is effectively ignored at steady state (i(∞)) because the inductor acts as a short circuit, allowing current to flow primarily through the 6Ω resistor. After t = 1, the introduction of a second unit step function alters the current's final value to ½ A. The reasoning confirms that the inductor's behavior justifies the exclusion of the 3Ω resistor in the steady-state calculation.
NewtonianAlch
http://img828.imageshack.us/img828/1149/70833278.jpg
Now this is a part of the solution that was given I was having difficulty understanding.
i(0) = 0 - understood
u(t -1) for 0 < t < 1 = 0
I can understand why the voltage from this source would be zero for that time period.
For any time t > 0 -> u(t) = 1, so V = 1
1) By i(∞) do they mean for the 0 < t < 1 period? So current just before t = 1? If so,
a) How is i(∞) = \frac{1}{6}? There's also a 3Ω resistor in there, why is that being ignored? Is it because for i(∞), the inductor is considered to be acting like a short-circuit thereby implying the current has to flow through 6Ω resistor, but ignores the 3Ω due to the path of least resistance?
i(∞) should be i after a long time, when currents and voltages have stabilized at steady state values.
I can't see why they say i(∞) = \frac{1}{6}.
Can't see a reason.
If the source on the right was of opposite polarity, then i would settle out at \frac{1}{6}.
Perhaps I should have posted the entire solution, although I was struggling to get the concept behind the first part, here it is in its entirety:
http://img832.imageshack.us/img832/6140/33110861.jpg
So they are saying if you were to sketch the current, i(t), then at time 0 current is 0 and while t<1 the current is an exponential that, left alone, would level off at 1/6 A. However, that behaviour continues only until t=1, at which case the other unit step is applied and causes i(t) to now head on an exponential decay towards a final value of ½ A.
Hmm yea that makes sense, I think I just got confused as to what they meant about i(∞), but it's clear now.
So does this mean the current through the inductor is \frac{1}{6} because that 3Ω resistor is not considered because that inductor is now acting like a short-circuit at i(∞)?
During 0<t<1 the 3Ω is not part of the calculation of the final current because the inductor is a short-circuit at t(∞) so shorts out the 3Ω so that none of the current from the 6Ω will pass through the 3Ω. Then at t=1, u(t-1) kicks in and changes the final value that i is headed towards. The inductor still acts like a short circuit at t=∞ but now there are two components of current passing through it.
Awesome, just wanted to make sure my reasoning was correct, thanks for that!
12K
9K
  • · Replies 17 ·
