Robotics Kits: Where to Buy Online?
  • Thread starter Thread starter darthxepher
    Robot
For beginners in robotics, the Basic Stamp and BOE Bot from Parallax are highly recommended starting kits. Online resources like Solarbotics, especially for Canadian buyers, offer affordable options. Engaging with local robotics teams through USFIRST can provide hands-on experience and community support. Additionally, hobbyist forums and bookstores can suggest valuable literature to aid in learning. Overall, these resources create a solid foundation for anyone looking to enter the field of robotics.
darthxepher
I want to get into robotics but need a starting point. I am wondering what particular robot kits i should buy first and where I should buy them! Any online sites that any of you guyz favor?
Thanks for your time :)
Take a look at http://www.parallax.com/" the basic stamp and a BOE are a good place to start.
You might also be able to find a http://www.usfirst.org/" robotics team in your area.
Is there a particular book that anybody recommends to get started in the field?
Solarbotics is also pretty decent, and may be cheaper if you're Canadian (they're based out of Calgary):
http://www.solarbotics.com
As for getting started, look up some hobbyist website / forums. Or the Books section of any of the stores above (and you can give them a call and see if they can recommend a book; usually, they'll be owned / operated by hobbyists, and not completely in it to ramp up sales, especially with newbies.)
I second the BOE bot. The basic stamp is a good way to start and the provided book is well written and easy to follow. I started with a regular basic stamp and legos and it was certainly a good way to go. The only problem is that basic stamps are so easy to use you will want to use them with everything project instead of using other cheaper controllers.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
