Robotics Kits: Where to Buy Online?
  • Thread starter Thread starter darthxepher
    Robot
For beginners in robotics, the Basic Stamp and BOE Bot from Parallax are highly recommended starting kits. Online resources like Solarbotics, especially for Canadian buyers, offer affordable options. Engaging with local robotics teams through USFIRST can provide hands-on experience and community support. Additionally, hobbyist forums and bookstores can suggest valuable literature to aid in learning. Overall, these resources create a solid foundation for anyone looking to enter the field of robotics.
darthxepher
I want to get into robotics but need a starting point. I am wondering what particular robot kits i should buy first and where I should buy them! Any online sites that any of you guyz favor?
Thanks for your time :)
Take a look at http://www.parallax.com/" the basic stamp and a BOE are a good place to start.
You might also be able to find a http://www.usfirst.org/" robotics team in your area.
Is there a particular book that anybody recommends to get started in the field?
Solarbotics is also pretty decent, and may be cheaper if you're Canadian (they're based out of Calgary):
http://www.solarbotics.com
As for getting started, look up some hobbyist website / forums. Or the Books section of any of the stores above (and you can give them a call and see if they can recommend a book; usually, they'll be owned / operated by hobbyists, and not completely in it to ramp up sales, especially with newbies.)
I second the BOE bot. The basic stamp is a good way to start and the provided book is well written and easy to follow. I started with a regular basic stamp and legos and it was certainly a good way to go. The only problem is that basic stamps are so easy to use you will want to use them with everything project instead of using other cheaper controllers.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
