Rocket Propulsion Homework: Calculating Mass Loss R
In summary, The problem involves a Roadrunner F45 rocket engine attached to a 2kg cylinder on a low friction wire. The thrust curve for the engine is given and 30g of propellant is burned upon ignition. The task is to calculate the average mass loss R during burnout in kg/s. The equation used is R = Ma/Vrel, where Ma is the average thrust and Vrel is the relative velocity. However, the value of Vrel is unknown and cannot be calculated without additional information. The impulse for the rocket has also been calculated, but a solution for R has not been found.
nns91
301
A Roadrunner F45 rocket engine, of mass 93g, is attached to a 2kg cylinder, which glides along a horizontal low friction nylon fishing wire. The thrust curve for the rocket engine is given.
In reality, 30g of propellant are burned as the engine is ignited. Calculate the average of mass loss R during burnout, in kg/s
R= Ma/Vrel
I guess Ma is the average thrust which I could calculate by using the graph. However, I don't know how to calculate V rel ( which is actually the next part of the problem). Is there any way I can calculate R other than use the normal formula ??
I have also calculated the impulse for the rocket.
Anyone found out about anything yet ??
I have been trying but still cannot find R without calculating Vrel
The average thrust can be calculated by taking the area under the thrust curve, which is 360 Ns. To calculate the average mass loss, we need to find the average velocity of the exhaust gases and the average mass of gas expelled per unit time.
To find the average velocity of the exhaust gases, we can use the ideal gas law: PV=nRT. Since the engine is burning 30g of propellant, we can assume that the exhaust gases have a mass of 30g as well. We also know the temperature and pressure of the exhaust gases (since the engine is in a closed system), so we can solve for the volume of the gas.
Once we have the volume, we can calculate the average velocity using the equation V= d/t, where d is the distance traveled by the gas (which is the length of the engine) and t is the total burn time.
Next, we can calculate the average mass of gas expelled per unit time by using the equation m= PV/RT. This will give us the mass of gas expelled in one second.
Finally, we can plug these values into the equation R= Ma/Vrel to get the average mass loss during burnout in kg/s.
Overall, this problem requires us to use the ideal gas law and basic kinematic equations to calculate the average mass loss of the rocket engine during burnout. It also highlights the importance of understanding the properties and behavior of gases in rocket propulsion.
FAQ: Rocket Propulsion Homework: Calculating Mass Loss R
1. How is mass loss in rocket propulsion calculated?
In rocket propulsion, mass loss is calculated using the equation Δm = mf - mi, where Δm is the change in mass, mf is the final mass, and mi is the initial mass. This equation takes into account the mass of the rocket propellant that is burned during the propulsion process.
2. What factors affect the mass loss in rocket propulsion?
There are several factors that can affect the mass loss in rocket propulsion, including the type of propellant used, the burn rate of the propellant, and the efficiency of the rocket engine. Other factors such as atmospheric pressure, temperature, and altitude can also have an impact on the mass loss.
3. How does mass loss impact the performance of a rocket?
The mass loss in rocket propulsion directly affects the performance of a rocket. As the mass of the rocket decreases due to the burning of propellant, the rocket becomes lighter and can accelerate faster. This results in a higher thrust and velocity, allowing the rocket to travel further and faster.
4. Can mass loss be minimized in rocket propulsion?
While it is impossible to completely eliminate mass loss in rocket propulsion, it can be minimized through careful design and engineering. This includes using more efficient propellants, optimizing the engine design, and reducing the overall weight of the rocket.
5. How is mass loss in rocket propulsion related to the rocket's fuel efficiency?
The mass loss in rocket propulsion is directly related to the fuel efficiency of the rocket. As more propellant is burned and the mass of the rocket decreases, the fuel efficiency increases. This is because less fuel is required to move a lighter rocket, resulting in a more efficient use of energy.
